RTX OctaneBench 2019 Preview
smicha
I'll send 4x and 8x rtx 2080ti this week.
Supernaut_13
Excellent, I can't wait to try this out.
Ryzen 7 2700X | Asus Prime B450-CSM | 32 GB DDR4 | GTX 1080 Ti Hybrid |
EVGA G2 1000W | Windows 10 Home
mojave
michax wrote:Image
Sadly still getting old good 418.* driver error.
Anyhow. Thanks for sharing! Nowadays, any info about true RTX benefit is good news. And 2.5x speedup for pathtracing increases card value so much!
I would also love to see how much faster denoiser is on Tensor Cores, especially on high resolution images where I assume benefit will be most significant. Similarly to RT Cores, where most of benefits
come from high poly scenarios.
We are aware of this, there's a note in the requirements section of the post where you can find the drivers required for this benchmark.
We are hoping to get an update from NVidia soon, hopefully this week, fixing this problem.
shapirog
Hey, I have an RTX 2070, but when I run it I'm not getting an "RTX On" benchmark. I installed the 416.94 driver. Is the 2070 supported at this point, or is there something else I should be doing? Would love to try it out.
mojave
shapirog wrote:Hey, I have an RTX 2070, but when I run it I'm not getting an "RTX On" benchmark. I installed the 416.94 driver. Is the 2070 supported at this point, or is there something else I should be doing? Would love to try it out.
Could you share either here or via PM a screenshot of the info that you get for this GPU using GPU-Z?
https://www.techpowerup.com/gpuz/
shapirog
eklein
shapirog,
The rtx 2070 works for me in Windows 10 with driver 417.35. I get with RTX On for 2x2070 almost 1300 score. See attach picture.
mojave
shapirog wrote:https://imgur.com/a/rgczZ88
Here it is!
In theory your GPU should be supported with the driver you use, however we didn't get the chance to test this combination in our lab so it would not be a surprise if RTX support came at a later driver for the 2070.
Would you be able to download this driver (417.71) from NVidia's website and check if this works for you?
http://us.download.nvidia.com/Windows/4 ... l-whql.exe
Thank you.
shapirog
Hey,
I tried both 417.71 and 417.35 and neither one is utilizing RTX. Anything else I can try?
HHbomb
RTX cards are really fantastic, but what about rendered image quality ? Same as before ?
