OctaneRender® for 3ds max® v2018.1-RC3 - 7.02 [OBSOLETE]
SergKlyosov
HHbomb wrote:Could we get a example how to use cryptomatte in octane 3dsmax ? pleeeaaazzz
+1 to this request
Some kind of a tutorial would be really great
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
paride4331
Hi Guys
I did a cryptomatte tutorial.
coilbook
HI,
Any news when octane will support Phoenix RGB so we can have smoke and liquids of different colors in one grid. And can mix them
coilbook
Hi Paride,
I am following up with 2080 TI failing.
I attached the video. When blank 3ds max is opened 2080Ti works ok. Once I load octane render preset called AO 2080 ti fails. Titan works fine.
SO now I am not even sure if it is hardware or software. yesterday everything worked great and nothing was changed.
Could you try to load this 3ds max preset and see if your 2080Ti fails if you have one.
UPDATE:
I installed 1 2080ti and it works. Then I removed a working one and reinstalled a bad one and now it works. It can work for awhile and then error can come back. Do you think it is a hardware problem?
Can 8 pin power cables to video card be the reason for cuda errors ?
AO.zip
(70.31 KiB) Downloaded 286 times
Gpu failure with max profile.MOV
(5.41 MiB) Downloaded 2742 times
neonZorglub
coilbook wrote:HI,
Hi coilbook,
A fix of the motion blur for particles will come soon (as in your sample with SuperSpray), then I'll check the issues with Phoenix FD and Forest pack.
You could try the new RC4 for max with your preset .. I tried it on my machine, no issue with 2 gtx titan..
coilbook
neonZorglub wrote:
coilbook wrote:HI,
Hi coilbook,
Thanks about the update. Please also look into eval times and multiple phoenix grids with different sim data . Thanks
Return to “Releases”
