Cinema 4D version 4.02.1-R3 (Obsolete stable)
momade
Sory. Me again:
Mixing GTX and RTX does not lead to issues right?
Just lost another GPU..
momade wrote:Sory. Me again:
We are not aware of any problems with mixing.
Silverwing
Thank you very much Ahmet for bringing the advanced EXR (Octane) Features to C4D.
Excellent work!
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
TonyBoy
Ahmet, any possibility that the latest build is compatible with C4D 15?
momade
Thanks Ahmet.
Seun116_1
Unfortunately 4.02.1-R2 is still not compatible with new Nvidia driver (418.81). Had to revert back to 417.71 to work with the new release.
TonyBoy wrote:Ahmet, any possibility that the latest build is compatible with C4D 15?
Sorry I couldn't solve yet this problem.
Kalua
Thank you, Ahmet. This release is working great! No complains so far!
Cheers!
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
sbstnc
forward wrote:I can confirm that the problems that sbstnc is having with an unresponsive LV are happening for us as well.
We also have a dual card setup and even switching off one card in the settings does not help with the interface freeze happening inside C4D.
Thanks forward, for adding to this.
It's a huge problem. The fact that this never used to happen, on this machine, no hardware change, no software changes, seems to indicate it's not hardware.
Followed all suggestions as to updating drivers, no effects. C4D UI still becomes impossible to use as long as LV is running. Even if LV not calculating... C4D thinks, hangs, thinks, hangs over and over.
I was going to try R2 but it doesn't seem that would help as there's no mention of this in the release notes.
Is this core or plugin issue? Open to more suggestions as what we might try.
Cheers
S
sbstnc wrote:Behaviour is the same as 4.01 versions, C4D interface can't be used when LV is on.
Mac OSX 10.12.6, CUDA 387.178, GPU 378.05.05.25f01
2 x 1080Ti, C4D R20
Any scene with a decent amount of geo and textures, say 4-gb VRAM.
It's like C4D stops while LV updates. As soon as LV refreshes with new samples, C4D becomes responsive for a split second, before stopping again while LV thinks some more.
What's going on please. This has only happened since 4 on a machine where nothing else has changed for 18 months. Updating 10.12.6 from 10.12.4 and new drivers has not worked. I have work to get out and I can't press a damn button.
LV on prevents any sort of viewport navigation. Can't pan, can't move around, because C4D is only responsive for 0.01 seconds every 3 seconds. Pause the LV (if you can manage to press the pause button in that 0.1second) then magically the viewport becomes super fluid and response, can pan all over, tons of geo, no problems. LV back on... can't click anything, C4D too slow, LV just keeps trying to refresh refresh, it's like LV is sucking up all system resources, but looking at stats, on an 8core C4D is 100% of 1 core and memory is fine.
I'm pretty frustrated now.
Edit: looks like some max users posting the same thing, RC7 OK but 4 onward no good.
viewtopic.php?f=80&t=70062&p=355577#p355577
viewtopic.php?f=81&t=70257&p=355087&hil ... e+#p355087
Is it core that's the problem? If so why?
I don't think it's a plugin issue, plugins are not using gpu itself. Core is running at background and using gpus.
1-Are you using e-gpu?
2-How is your device settings and others part in settings?
3-Try with parallel samples=1 and max tile samples=1 from kernels. And try to use "sub sampling=2x" if makes any difference.
Other than this send me PM for a remote connect.
Return to “Releases”
