OctaneRender 4 for Rhino (TEST and STABLE)
Forums: OctaneRender 4 for Rhino (TEST and STABLE)
copy of nodes not possible
Postby v-cube » Fri Feb 01, 2019 8:52 pm
v-cube Fri Feb 01, 2019 8:52 pm
Hello Paul,
I just noticed that it is not possible to copy and paste nodes in a material ( I am using rhino 6), I use this 50 times a day, can this be fixed ?
thanks
Andreas
4 machines, each with 1 X1070 GTX and 1 X1080 Gtx cards core i7, 32 GB RAM http://www.v-cube.de
v-cube
reflection in display port not updating
Postby v-cube » Fri Feb 01, 2019 9:02 pm
v-cube Fri Feb 01, 2019 9:02 pm
Hello Paul,
when I create a new octane Material in the ME, it is a glossy material by default. After assigning it to an object, the object is displayed with a reflection in the Rhino viewport ( my setting is "shaded" with the "color and material usage" set to "Rendering material")
Now I change the octane material type to diffuse, but the reflection is still there (see pic...) there seems to be an update issue, because changing the opacity value back and forth seems to fix it...
best
Andreas
v-cube
Re: OctaneRender 4 for Rhino (TEST and STABLE)
Postby face_off » Mon Feb 04, 2019 7:32 am
face_off Mon Feb 04, 2019 7:32 am
I will check with McNeel to see if this is possible.
McNeel are currently working on an issue that is related to this, so I hope it will be addressed in the next release of Rhino6.
Postby v-cube » Mon Feb 04, 2019 7:31 pm
v-cube Mon Feb 04, 2019 7:31 pm
I really hope it is possible, I use it in R5 / octane 3.8xx all the time, it is important for a fast workflow, not having it would be a huge step back and really annoying IMHO !
best
Andreas
v-cube
Postby Bendbox » Tue Feb 05, 2019 1:23 pm
Bendbox Tue Feb 05, 2019 1:23 pm
Hi V-Cube,
This is possible, I do it all the time -- once you right click, click on "expand all" and the Copy and Paste functions will reveal themselves.
Ryan
Win10x64 / i7 6850K / 16g RAM / 4 x GTX1080
Bendbox
Re: copy of nodes not possible
Postby Refracty » Tue Feb 05, 2019 3:20 pm
Refracty Tue Feb 05, 2019 3:20 pm
Is this only a Rhino V6 related issue?
v-cube wrote:Hello Paul,
thanks
Andreas
3D Animation & 3D Visualisierung Köln, Germany
www.lichtblickstudio.com
High End CGI, Animation and VFX from Cologne
Refracty
Postby v-cube » Tue Feb 05, 2019 4:23 pm
v-cube Tue Feb 05, 2019 4:23 pm
Bendbox wrote:Hi V-Cube,
Ryan
Hi Ryan, thank you for the hint, I wasn't aware of this!
Although this will ease my pain quite a bit, I would prefer the copy option to appear directly after the first click and if possible even work with control -C and control-V
best
Andreas
v-cube
Postby Bendbox » Tue Feb 05, 2019 9:13 pm
Bendbox Tue Feb 05, 2019 9:13 pm
v-cube wrote:Although this will ease my pain quite a bit, I would prefer the copy option to appear directly after the first click and if possible even work with control -C and control-V
I agree, this would be nice. I constantly copy and paste as well when making new materials.
Bendbox
Postby Refracty » Tue Feb 12, 2019 1:00 pm
Refracty Tue Feb 12, 2019 1:00 pm
Hello Paul,
any news about 4.02.1 ?
Cheers
Nando
Refracty
Postby face_off » Wed Feb 13, 2019 4:22 am
face_off Wed Feb 13, 2019 4:22 am
I have updated the STABLE installers at the top of this thread with:
4.02.1.104
- Compiled with Octane 4.02.1
- Increased the maximum resolution to approx 15k x 10k (on a 16GB RAM system).
- Fixed issue where importing an ORBX when adding a material for a layer was not working correctly
- The Albedo of a Universal material is now rendered in the Rhino Rendered preview window
- Multiple changes to fix issues with Octane material previews, and the appearance of Octane materials in the Rhino Rendered and Raytraced viewports. NOTE: This will need the final release of Rhino6 SR13 to work correctly
PreviousNext
Return to Rhinoceros 3D
Sun Oct 25, 2020 8:26 pm [ UTC ]
