I'm now a proud owner of a Houdini Indie license
OctaneRender™ 4.01 for Houdini™ - production build 4.01.1.1
- Ferdinand13
Hi Juanjo,
I've also managed to install Octane and it basically works within Houdini. However, when I preview the scene via the IPR viewer, all objects are shaded in magenta. Even adding new Octane materials to the objects don't change that. Any ideas why and how I can fix this? Thanks for letting me know.
Custom PC, Intel Core i7-6800K, 48GB RAM, 3x MSI GeForce RTX 2080 Super Seahawk EK, Windows 10
Razer Blade Pro 17, Intel Core i7-10875H, 32GB RAM, 1x NVIDIA GeForce RTX 3080, 1x EVGA GeForce GTX 1080 Ti Hybrid (eGPU), Windows 10
Have you assigned the Octane material as an object property? If so there may be Mantra or other non-Octane materials assigned via a material node in sops. This would override the object property assignment causing Octane to use the pink diffuse where it can't find a valid material.
If that is not the problem you may want to post screengrabs or a hip file.
- Ferdinand13
Hi Juanjo and Jandress,
Thanks a lot for your suggestions!
Will keep them in mind for next time. Meanwhile I realised that the path I had entered for the material in Houdini (applying it to a geometry node) was too 'deep'. I had entered "shop/octane_glossy1/octane_vopnet", when I should've stopped at "shop/octane_glossy1". You live and learn
- Jolbertoquini
- Contact:
Hi Juanjgon,
Any news for Orbx proxy?? Maya Plug/ C4d and others has is quite useful on the plugs to share thing and get used on different plug, Any news we quite waiting for a while on this.
Cheers,
JO
Cheers,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
The final full support of the OSL nodes exposing the OSL parameters as input pins, and the .orbx proxy referencing are the two main features that are under development right now, so I hope to have good news about them soon
- Jolbertoquini
- Contact:
juanjgon wrote:The final full support of the OSL nodes exposing the OSL parameters as input pins, and the .orbx proxy referencing are the two main features that are under development right now, so I hope to have good news about them soon
Hi Juanjo,
Awesome, so we may have soon!, this will be really good for us we can't wait to have our hands on that proxys! The C4D version with the preview of the mesh is really good, Maya Plug has just a Box which is not a bounding box is sometimes hard to work with. What your plans on preview mesh of the orbx?
Cheers,
JO
Hi Juanjo,
great news, will the ORBX-proxy-features be integrated in 4.02?
When can we expect 4.02?#
Thank you
Nando
Thank you
Nando
