OctaneRender® for 3ds max® v4.01.1 - 6.12 [OBSOLETE]
paride4331
mbetke wrote:I tested with new registry settings. It renders without crash but the computer hangs, lags so hard that I only can do one thing every minutes until driver crash. :(
Only with this scene and displacement.
I will give up on this and built the metal framing with geometry...would appreciate a solution for further versions because it is something wrong in Octane.
Hi mbetke,
could you try as follow?
mbetke
Nothing changed. Crashes the driver.
Does the roof with displacement work for you? I mean the vertical grey parts with the black/white displacement map.
PURE3D Visualisierungen
paride4331
mbetke wrote:Nothing changed. Crashes the driver.
Hi mbetke,
I had some GPU failure, with or without displacement , I sent your scene to developers .
mbetke
Okay. then this is a new one. I always had only problems with displacement.
Since I rendered the finals out of the scenes with geometry the only "bug" I had today was the non working denoiser. All checkboxes were checked and I clicked it some times but denoiser just didn't kicked in. Of course I selected the denoised beauty pass.
paride4331
mbetke wrote:Okay. then this is a new one. I always had only problems with displacement.
Hi mbetke,
did you check in Octane camera and in device pannel?
try activating cpu memory
mbetke
Yes I checked. 8Gb free vram while rendering. No issues there with 24GB in total.
paride4331
mbetke wrote:Yes I checked. 8Gb free vram while rendering. No issues there with 24GB in total.
Hi mbetke,
had you experimented something like that?
viewtopic.php?f=36&t=70151
mbetke
No crashes. I now checked "denoise on completion" and then it works. One GPU used for Denoise, the other one for Tone-mapping.
paride4331
mbetke wrote:No crashes. I now checked "denoise on completion" and then it works. One GPU used for Denoise, the other one for Tone-mapping.
Hi mbetke,
this issue should be fixed simply checking/unchecking or pressing rebuild geometry.
HHbomb
in this release I can't manage to render "Active Layer ID". Sometimes it works, sometime it take in account just few objects with same ID.... It is really a pain.
Before It worked like a charm...
Hope it can be fixed.
EDIT : It is related to Octane scene Persistency...... If I keep all nodes, octane don't see the ID nodes modifications. Now I know :-)
Return to “Releases”
