Denoiser stops render: bug still active?
Reality4
Hi everyone,
After rendering a couple of seconds, I get a "GPU failure" and the log says:
OctaneRender 4.01.1 (4010100)
denoiserThread0 : Not enough free memory to run the denoiser. Required memory 338.17 MB
Is there a way to circumvent this issue? My system has more than enough memory and with previous versions of OctaneRender I never had denoising issues like this.
paride4331
Hi Reality4,
338.17 MB is VRAM needed, not RAM.
Try checking "use CPU memory" it could solve your issue.
Let me hear from you.
Reality4
Thanks Paride, that did the trick!
Return to “Autodesk 3Ds Max”
