OBJ Export Settings for Octane
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
James
Here are screenshots of OBJ export settings that work with octane, please share export settings for apps not yet in this list and I will pop them in this post.
3DS Max
3DS Max
Blender
XSI
On a related note, here is what to do when importing into octane...
To make sure that scale is correct, you should select the units that you have been modeling in, for example in you modelling app, if you have been modeling 1 unit = 1 cm, you should select CentiMetres in the dropdown box in the import preferences, which can be found from the file menu.
Kubuntu 9.04 | Nvidia Gainward 9500 GT | Intel Core2 Quad 2.40 Ghz | 4 GB RAM
radiance
This is a very good idea James,
please everyone, if you can add some screenshots of configurations here,
and we can include them in the upcoming documentation :)
Radiance
pixie
James wrote:Here are screenshots of OBJ export settings that work with octane, please share export settings for apps not yet in this list and I will pop them in this post.
In blender I usually add normals and HQ, at least it had done no arm so far.
radiance
Yeah, exporting the normals is needed, especially when using glass materials as the normal is used for the refraction.
Here's my setup i'm using with blender to export a scene completely.
Radiance
pixelrush
it may be a good idea but its already getting confused with different settings and comments added. I wonder if the mods can edit this thread as we go so just the relevant info is available for quick reference. We dont want to end up reading through 20 pages to discover we should follow whats on p5 or something :)
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
Sam
Screenshots are gonna be in James first message, he just need to add them in a regular basis
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
James
I will keep checking back and making sure that everything is in the first post.
thwak
Is this correct for 2.49?
Ubuntu 9.10 x64 | GTS 240 | 260.19.44 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb| Blender 2.56a/latest Yoyoz plugin
WinXP32 | GTS 240 | 266.58 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb | Blender 2.56a/latest Yoyoz plugin
WiKKiDWidgets
thwak wrote:Is this correct for 2.49?
I also poke the HQ button.
Vista 32 (<--EEEW!)| Intel Quad Q6600 2.4Ghz | 4Gb ram | Dual NVidia GTS 250 1Gb (Non-SLi)
pixelrush
I had a mesh ex Blender that kept crashing Octane.. very perplexing.
Finally found the culprit- a stray edge - dont export edges, Octane doesnt like it and doesnt give a specific error.
Better yet in edit mode use the built in script Clean Meshes to tidy up verts and edges.
Also I remind people to Remove Doubles, and Clear/Apply scale and rotation as good housekeeping habits.
Octane v1.55
Return to “Resources and Sharing”
