Cinema 4D version 4.01.1-R2 (stable) 13.12.2018
thanulee
Hi, i get c4d freeze when i try close node editor. Empty scene. R19! Complete freeze of c4d i have to end task from task manager.
I have both 3.08 standalone and 4.00 standalone installed, is that a problem?
edit: i restarted pc c4d doesnt freeze. I add a material those on 3 spheres, i get a crash...
I attach bug report.
win10/411.63 drivers
_BugReport.txt
(385.35 KiB) Downloaded 341 times
eyeonestudio
Panorama Rendering - Individual axis option needs
I am planning to render with Cube Map(panorama).
It is not for the VR Device(HMD).
Final rendering should be very high resolution. And I only need 3 of 6 sides.
Rendering 6 sides takes too long time.
However, my scene has a large number of generators, making it difficult to output orbx.
Standalone Camera has an X + X -... options.
Could you add individual X + X -... in Cube Map?
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
thanulee wrote:Is this a glitch? ty
https://www.dropbox.com/s/ku5mtvj2k75yx ... .webm?dl=0
nope! It keeps size and try to fit pins and no place for preview area. Make it higher and you'll see previews.
thanulee
Thanks, also which gpu should is better to use for denoising? The one attached to screen or the other one?
thanulee wrote:Thanks, also which gpu should is better to use for denoising? The one attached to screen or the other one?
Not sure but probably the gpu with more vram
Kalua
Aoktar:
I have a few questions regarding the .ORBX export/saving process:
1. Are instances recognized as "instances" inside an .ORBX file? If so, would instances make this .ORBX file smaller or more efficient?
2. Is hidden geometry in the scene imported to the .ORBX file or only the visible scene?
Thanks for all the good work you've done so far!
Octane User since V1 Beta
Kalua wrote:Aoktar:
1. There's not instance object but acts very similar. They are converted to scatter node with many matrices. It works very similar way.
2. Hidden geometry will not exported to Octane.
thanulee wrote:Hi, i get c4d freeze when i try close node editor. Empty scene. R19! Complete freeze of c4d i have to end task from task manager.
Is It first time to try V4? Having V3/V4 standalone is not a problem. But another plugins maybe a problem.
thanulee
Yes my friend, first time the stable version. I had tested the previous RCs as well, and i had similar issues, mostly cuda errors.
What other plugins u suspect? I use TFD/XP/Realflow/Forester as main plugins! thanks
Return to “Releases”
