Cuda Error 700
Loopinglovers
Hi Guys,
Getting Render Failures on a fresh C4D scene with some cached .mdd files. Same in V3.08 and V4.01. Any idea ?
It’s not textured yet. Just imported my .obj and the .mdd files.
It starts rendering in the viewport but after 2-3 refreshes it fails.
Using C4D R20
2x RTX 2080Ti
AMD TR 2950X
X399 Taichi
Started logging on 17.12.18 11:38:03
OctaneRender 4.01.1 (4010100)
CUDA error 700 on device 1: an illegal memory access was encountered
-> failed to wait for event
device 1: direct light kernel failed
CUDA error 700 on device 0: an illegal memory access was encountered
device 0: direct light kernel failed
-> could not get memory info
-> failed to unregister pinned memory
-> failed to load symbol data to the device(deep_data)
device 1: failed to upload the deep params
device 0: failed to upload the deep params
ASUS PRO - WS WRX80E - SAGE SE
AMD RYZEN THREADRIPPER - PRO 5955WX
3X NVIDIA RTX 4090 FE
2X DARK POWER PRO 13 - 1600W
CORSAIR VENGEANCE RGB PRO 256GB
NZXT KRAKEN ELITE 360
How many triangles do you have in scene? And how much big for one biggest mesh?
hypoetical
Did you figure out what was wrong? I'm getting the same issues with 3x RTX 2070s. :( Can't fix it, it's been down all day.
NNelson
I'm having the same issue on a near identical system I got this weekend. Tried new/old Drivers, Windows refresh, enabling/disabling the GPU... at this point i feel like it's gotta be a faulty card. Realllly was hoping to avoid dealing with manufacturer returns. :roll: Luckily one of my two 2080 TIs is working properly.
coilbook
can anyone try octane 4 RC7 build to see if you have cuda errors or crashes It seems that after this build when all the problems started.
Loopinglovers
Still having this problem - Did anyone discovered a fix?
coilbook
Loopinglovers wrote:Still having this problem - Did anyone discovered a fix?
were you able to solve it? I have the same problem and it is related to rtx cards. Thanks
