Hi aoktar,
congrats on the new built. And looking forward to future updates.
I think in this update the FILM REGION is not working the way it's supposed to work. It's still rendering the whole scene instead of the REGION.
btw, love this addon. took me a while to understand but later got the grip and loved it.
+ a suggestion if you could add the samples in the FILM REGION instead the samples staying 0 on the film region while it's showing the whole in the taskbar (like it does).
						Cinema 4D version 4.01.1-R2 (stable) 13.12.2018
The .OBRX loader is great. Is it normal to .c4d files containing multiples .ORBX files take longer to load when opened?
The build is great despite the problems I have with shaders preview I mentionned earlier (funny thing is the shader preview in the node editor behaves correctly).
Cheers!!
Cheers!!
C4D 2025.4 Octane 2025.4 v1.7.2, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
Plugin will load every orbx one time and it can take a while.Kalua wrote:The .OBRX loader is great. Is it normal to .c4d files containing multiples .ORBX files take longer to load when opened?
Cheers!!
Hi! You should send more details if you wish to help. I described how to do on the first page of this topic. Thanks!steph wrote:Hello,
i noticed octane crash when i'm doing a back reading with a animate backroom ...
Sorry for my English
Hey there!
I tried to update to the new version and, when I did, Octane told me I did not have licenses for either Standalone or the C4D plugin (??) so I reinstalled 4.0 and everything works again!
EDIT: DISREGARD! I downloaded the licensed version instead of the subscription version! User error is the most common error
						- jsuarez388
Hello everyone!
Ahmet, thanks for your continued effort to make this plugin the best it can be. That being said, I found a couple of bugs that I would like to report.
*I apologize if these have been reported already, unfortunately I don't have the time to go over 5+ pages of posts to check*
- After pausing the live viewer once, the icon stays "on" for a long time, even when it is not paused.
- For some reason when keeping the LV docked in the interface it's impossible to get the bottom data information, it only becomes available when undocking and re-docking the LV. I personally have a custom layout and like to keep the LV docked. - Activating the Post effects in the Beauty passes disables it from the Main render tab in the LV. It only becomes visible as a separate pass. This behavior was definitely not there before.
My system specs:
AMD Ryzen 7 1700
GeForce GTX 1070 x2
16GB Ram
Running Windows 10
Octane Render V4
						AMD Ryzen 7 1700
GeForce GTX 1070 x2
16GB Ram
Running Windows 10
Octane Render V4
I had noticed this behavior for a very long time, I cant even remember when it didnt work like thatjsuarez388 wrote:Hello everyone!
Why impossible? I'm using docked or undocked every seconds, not seeing any problems. Just not that in latest build, I made some tweaks to display more fps. It will not display stats while cspp is lower than 8.jsuarez388 wrote: - For some reason when keeping the LV docked in the interface it's impossible to get the bottom data information, it only becomes available when undocking and re-docking the LV. I personally have a custom layout and like to keep the LV docked.
Thank you so much for the ORBX Loader, its a huge benefit in a current project. Just tested it and although it crashed C4D after hitting the reload button, I'm pretty excited about it.
Just 2 questions:
1) I'm using it now to load a rigged and animted chracter into my scene. Scaling and moving the orbx Object supports motion blur and it works for my needs, but it looks a little odd. Further I noticed a error when playing the animation (motion blur adds a whol bix around the character) but it looks flawless by going frame by frame.
2) are there any plans for implementing the time offset? It would be great to load several ORBX Loader objects and just offset them a little bit (I guess that would even work with on ORBX Loader object and a cloner).
Edit: Should we use an Octane Tag inside the scene or on the ORBX Loader?
							Just 2 questions:
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
