speed : preview vs. render
Forums: speed : preview vs. render
Postby protovu » Tue Dec 04, 2018 11:34 pm
protovu Tue Dec 04, 2018 11:34 pm
Hello Fellow BlendOctaners,
My Octane render preview is fast. With a medium complex model which is using transparent surfaces, I can snap anywhere in the timeline and regardless and get a 1.5 image with about 50 samples.
Not so when I go to do an actual render with the same settings. Very slow.
I was thinking that this might be due to mesh compilation, but the same compilation occurs in Preview Renders, yes?
How can I emulate the speed of the Preview Render in an actual animation? Frames without Denoiser about 6 seconds. With Denoiser about 14 seconds.
I must be missing something obvious.........
Thank you for the help.
Win7 64
dual xeon
32 G RAM
970,980 Ti, 2x TitanX
Nvidia Driver -4.17
StandAlone 4
Octane_Server_4.0_-_16.3
Blender_Octane_Edition_16.3_2.79
protovu
protovu
Re: speed : preview vs. render
Postby ChrisH » Tue Dec 04, 2018 11:48 pm
ChrisH Tue Dec 04, 2018 11:48 pm
What resolution is your render and how big is your "preview window".
I think it's the resolution that is most likely to be the reason to differences in "render times"!
Usually my preview area/window is not more than 1/4 of my screen (very rarely full screen), and my final renders are from 1080, to 4K, to more...
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
ChrisH
Postby protovu » Wed Dec 05, 2018 12:51 am
protovu Wed Dec 05, 2018 12:51 am
Thanks for the response, Chris.
At your prompt, I just stretched out my preview to about 1920 x1080 , taking most of the secondary monitor.
The preview is still really fast. About 3 seconds.
The Render, at 1280 x 720 is about 12 seconds.
Doesn't seem to make sense, does it?
What really puzzles me: I don't see the lag from mesh compiling that I see in the actual render. After the initial compilation, the render just snaps into place as I move on the timeline.
This is what I want for test renders!
protovu
Postby grimm » Wed Dec 05, 2018 1:11 am
grimm Wed Dec 05, 2018 1:11 am
Short of it just being a bug, have you taken a really close look at how you are setting up the object types? If you are seeing a lot of mesh recompiles, it could be the issue.
Linux Mint 20 x64 | Nvidia GTX 980 4GB (displays) RTX 2070 8GB| Intel I7 5820K 3.8 Ghz | 32Gb Memory | Nvidia Driver 455.28
grimm
Postby protovu » Wed Dec 05, 2018 1:21 am
protovu Wed Dec 05, 2018 1:21 am
Thanks, Grimm.
I am new to Blender, not to 3D. I am not sure what you mean by object types, actually. Primitives, for example?
If there is a recommendation on how to set up object types regarding mesh complement, please forward.
Even so, why would object types be a non-issue in the preview render? Same models and Keying.
protovu
Postby J.C » Wed Dec 05, 2018 2:08 am
J.C Wed Dec 05, 2018 2:08 am
Take a look here:
https://docs.otoy.com/BlenderH/BlenderP ... yTypes.htm
Modifiers can slow down a lot compilation time especially CPU extensive like Subdivision surface. You can apply them before rendering an animation.
As far as rendering animation in viewport is concerned I wonder too why it does compile every frame during final render while in viewport it is not.
CPU – i7 8700k 4.8Ghz + 64GB RAM, GPUs: 4xRTX 2080, 2xGTX 980 Ti.
System – Windows 10, Octane 4-2020, Blender Plugin 17.x-21.x
J.C
Postby protovu » Wed Dec 05, 2018 4:31 pm
protovu Wed Dec 05, 2018 4:31 pm
Hi J.C.,
The modifiers don't seem to slow the Preview Render at all.
It is as if in the Preview Render, the file is loaded and ready, regardless of which frame I am on.
And with an animation Render, the file is being reloaded for each frame.
This sure seems wrong.
Totally slows the process.
I would be very happy with the Preview Render output for an animation.
Anyone else experiencing this difference?
I will dig into the page you referred. Thank you for that.
Rick
protovu
Postby J.C » Wed Dec 05, 2018 5:37 pm
J.C Wed Dec 05, 2018 5:37 pm
It's always been this way since beginning. This needs some clarification from the developers.
J.C
Postby protovu » Wed Dec 05, 2018 5:59 pm
protovu Wed Dec 05, 2018 5:59 pm
Is there a way to push this question up the food chain?
I see no relief from designating object types.
protovu
Postby J.C » Wed Dec 05, 2018 7:13 pm
J.C Wed Dec 05, 2018 7:13 pm
I will forward this to Lino. He is closer to developers.
J.C
Next
Return to Blender
Users browsing this forum: No registered users and 5 guests
Tue Jan 26, 2021 9:39 am [ UTC ]
