BG Random UV Projection node
Hi all,
here is an OSL Projection node to randomise position, rotation and scale of the uvs of scattered objects. It uses the Random Color Texture node to obtain the random values, but you can use any other texture node:
https://vimeo.com/296310449
Hint #1:
Connect the same Random Color Texture node used to drive the OSL Projection, firstly into a Gradient node to batter control the range, and then in the Power pin of the ImageTexture node, to randomly change also the aspect of the texture over clones:
Here is the OSL script:
BGrandomUVproj_osl.zip
(931 Bytes) Downloaded 1369 times
an .orbx example scene:
BGrandomUVproj_orbx.zip
(368.75 KiB) Downloaded 955 times
and a c4doctane example scene:
BGrandomUVproj_c4d.zip
(465 KiB) Downloaded 1213 times
Hint #2:
If you use the following OSL Texture node RandomInstanceColor.osl, provided by Milanm here:
#include <octane-oslintrin.h>
shader RandomInstanceColor(
      int Seed=0,
      output color c = 0)
      c = noise("cell",_getinstanceid(),Seed);
Instead of a Random Color node, the BGRandomUVProjection OSL node works also with non instanced objects too.
In Standalone you need to have a Scatter object connected to each different object:
While in c4doctane you need to add an Octane Object tag, with differet Instance ID numbers, for example selecting all the tags, and entering num+1:
Here is a a Standalone .orbx, and .c4d example scene with both osl scripts working together:
randomuvsonobjects.zip
(2.32 MiB) Downloaded 1125 times
Happy GPU Rendering,
ciao Beppe
FxDesign
That's fantastic, thank you
funk
Thanks Beppe. Very handy!
J.C
Wow!. Awesome script. Thanks for sharing Beppe!
System – Windows 11
I have updated the first post with the great hint provided by Milanm here, of using the OSL Texture node RandomInstanceColor.osl, instead of the Octane Random Color node.
ciao Beppe
pxlntwrk
thanks bepeg,
that's really cool and useful...
pxlntwrk.net
neilmanisharma
Can you tell me how it will work in blender? As i tried using OSL texture but it is giving error.
roy_orengo
Hi Beppe,
You wrote:
"Instead of a Random Color node, the BGRandomUVProjection OSL node works also with non instanced objects too".
So I could use It without Blocks (I'm using Rhinoceros as modeller)? On different solids?
ciao,
Roy
mortom_ckm
Hi I'm green in this stuff - In Octane I mean :)
There is a way to do this in Octane for Blender? I suppose connect node "OSL Projection" with script to the shader it's not do the trick?
mortom_ckm
Hi
There is a way to do this in Blender?
Return to “Lua Scripting”
