Run Octane for C4D |Big Lag on system
visuall
Hi aoktar, I hope you're fine, my problem is found.
Can you tell me where do I get the problem when I run octanerender live viewer? the complete system lag. When I pause it, everything comes back to normal.
(Out of Core disable, Open GLdisable, all disable actually);)
Thanks in advance.
All drivers are updated.
OCTANE STANDALONE 4 | Octane For C4D | Win7/64 | 2XGEFORCE GTX1060| I7 3770 | 32GB
Ron
Did you switch on 'Use priority' in Settings/Devices for the GPU that has your monitor attached?
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
visuall
I tried both options, but nothing changes
Ron
Does this happen in every scene or only in a heavy scenes with lots of textures and objects?
visuall
Small or Heavy scene
SInce one week this problem is récurent .
Restore system, re-install all soft, but Nothing .
Testing Cpu, RAM and all is possible test. Nothing
Is very annoying.
especially as with standalone everything is fine.
Ron
Did you have this issue with 3.08, too?
It is a known issue with V4 /C4D in viewport to be a bit laggy ...
visuall
Tomorrow re-install 3.08 for test.
indeed apparently since the V4 that lag.
Standalone and plugin in 3.08, thats right?
visuall wrote:Small or Heavy scene
Is very annoying.
What's OS, c4d versions? And gpus?
Reinstalling which softwares? You don't need to reinstall octane. Plugin is just extraction from package.
Better to try different drivers with clean install. Start with latest.
visuall
Win7/64 | 2XGEFORCE GTX1060| I7 3770 | 32GB last driver nvidia (the test with the old drivers gives the same result)
I do not know where to look for everything to return to normal. It's almost impossible to work with the plug-in.
Today I re-install version 3.08 standalone and plug-in, but it's still the same. I wonder if it's just not my pc that is definitely obsolete. :cry:
GIOLETS
mmm. could you check if perhaps you are in the old LUT camera missing file problem?
viewtopic.php?f=30&t=67778&p=339735#p339735
i9-10900x, 96GB DDR4, 2xRTX 2080 TI, ASUS X299 SAGE, Windows 10
http://www.visual4d.it
