NodeGroup not working in materials (4.00 v16.3)
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
ChrisH
I'm having a problem with NodeGroups in materials not working. I made new file to test it (attached), to make sure the problem wasn't with the file I was working on.
If I'm in Rendered View/Interactive Mode and create a group of some nodes in a material, the viewport won't update and the status stays at "Waiting for image...".
It doesn't update if I make changes to the shader etc in the group (not until I ungroup the node group). If I zoom, pan etc the Viewport will update, but with the material as it was before creating the node group.
If I then update the scene (or stop/start the rendered view), or do render the image, that node group will appear as an white diffuse (standard/unassigned material), even if I use mix nodes etc.
I've looked at the logs and can't see any messages that differ from before I create the node group to after.
Screencast showing the problem: https://drive.google.com/file/d/1w6AqgP ... sp=sharing
A. Windows 10
B. GTX 1080 - 8GB
C. 16GB
D. 398.11
E. 3.08
F. 4.00 v16.3
G. Blender 2.79b
OctaneNodeGroupTest.blend
(575.66 KiB) Downloaded 241 times
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
J.C
It looks like the Node Graph Upload Optimization needs to be fixed so Node Groups can work.
For now just turn off "Node Graph Upload Optimization" in the Octane options if you need Node Groups in your scene.
System – Windows 11
ChrisH
Thank you, turning off "Node Graph Upload Optimization" worked!
Return to “Bug Reports”
