OctaneRender™ 2018.1 XB1
natemac00
Is there an example of the volumetric spotlight that isn't in a black abyss?
I feel demos always show volumetric lighting in nothingness and then when you put it in a real-world situation it never looks good... Prove me wrong please.
______________
Nate Mac - Chicago, IL
Cinema 4D R26.107 | Octane 2021.1.6
Main: AMD ThreadRipper | Win10 | 32-core | 128GB | RTX A5000 & GTX 2070 SUPER
Slaves: 4x GTX 980 Ti | GTX 1080 | GTX 1070 | GTX 1070Ti
Goldorak
natemac00 wrote:Is there an example of the volumetric spotlight that isn't in a black abyss?
Interior->Daylight->Medium->godrays + Volumetric_Spotlight =
Daylight only:
Spotlight only:
Notiusweb
Imagine if we could shape those lights into IES lights.... :geek:
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
divasoft
Goldorak wrote: Interior->Daylight->Medium->godrays + Volumetric_Spotlight =
I can't find Volumetric light node in node list.
it has not added to 2018 XB1 yet?
natemac00
The attachment godrays+spot2.png is no longer available
Daylight only:
The attachment godrays_sunpng.png is no longer available
Spotlight only:
The attachment godrays_spot.png is no longer available
Thank you, these look great. is there any control of fall off?
______________
Goldorak
Daylight only:
Spotlight only:
The throw distance is what I was using the shape the light above the way I wanted (mixed with scale and cone size). You can also adjust the medium within an individual light volume rather than sharing the same global medium settings across all lights and the environment.
The volumetric light nodes don’t show up in the node list in XB1, but this should be fixed in XB2.
FrankPooleFloating
Is there any chance of finally getting backface culling in Octane any time soon? (for fading whole meshes without showing their innards)
Goldorak
FrankPooleFloating wrote:Is there any chance of finally getting backface culling in Octane any time soon? (for fading whole meshes without showing their innards)
What about using polygon side node as input into visibility?
milanm
This is not about hiding back facing polygons. It's about hiding the semi-transparent front facing polygons that are seen through other semi-transparent front-facing polygons. And, at the same time, without hiding polygons of other objects.
Using raytype() in opacity we can hide an object from refractions, including its own refractions, but then that object is invisible behind glass. So, that trick can only be used for a limited number of cases and I'm pretty sure, not that many people are even aware that this can be done in Octane.
RaytypeAndRefraction.orbx
(2.6 MiB) Downloaded 274 times
So far I couldn't find a way to hide those overlapping polygons on a per object basis yet in Octane. So, my question is simple: Spectrons?
Cheers
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
FrankPooleFloating
Thanks for clarifying that milanm. Hopefully Jules & Co are understanding us now. Whatever terminology one wants to use to describe the ability to fade in/out an object in 3d and not see the insides, this is what we need.. those of us who do technical renderings, infographics, instructions. If Otoy's goal is to be able to do virtually anything in Octane, this is one of the missing pieces, for sure. One shouldn't have to do a complex Render Layers and Compositing setup just to have transparent objects in their scenes. Please guys, make this happen already. Let Back to the Future and Star Trek be your inspiration. ;)
