OctaneRender® for 3ds max® v4.00 - 6.10 [OBSOLETE]
neonZorglub
SergKlyosov wrote:Hi neonZorglub
For image tiles node there is no compression options available. Once again, this feature exists in Standalone
Hi SergKlyosov,
Thanks for letting us know.
This will be fixed in the next version.
coilbook
When will we see two or more different volume textures in one phoenix grid? (phoenix supports RGB mixing)
For instance, mixing liquids of two different colors or two different smoke colors in one grid. Will it happen or only vray can do it? Octane is pretty bad at two or move overlapping grids. Maybe we can finally get RGB support
In the image attached I need black diesel smoke mixing with white ire smoke. How can I do it?
mbetke
Hi mbetke,
When creating a new object, the 'movable proxy' is set as the last object that was edited in the properties.
This avoids to have to set / unset this for each object, while creating many objects.
This behavior can be turned off in Global settings / Main settings / : 'Re-use last properties for new nodes'
(the default will be movable proxy: off for each new object)
Thanks. I already wondered why sometimes models have a flag a movable proxy and sometimes not.
PURE3D Visualisierungen
Chug
Just to be sure...
When it is said that bugs found in Octane 4.0 and 3DS max plug-in 6.10 will be fixed in the "next version", does that mean that all 4.0 6.10 owners will get it or only people having subscribed to the all-access monthly payment ?
neonZorglub
Chug wrote:Just to be sure...
Hi Chug,
Sorry, for the 'next version' I mentioned, I meant the next release of the plugin, with no change in the license, so no worries.
It will still be using octane 4.0, and will have a version named like 4.0 - 6.11 or 4.01 - 6.11
WhaleHunter
Hi neonZorglub,
Bug:
Octane Mix material with xref octane materials as inputs = max crash
as soon as you hook up the 1st xref material into the mix input slot, max crashes.
N.
nildoe
Ornatrix Hair is not being hidden, but it is hidden in explorer, viewport.
Also is there a way to speed up material editor? everytime i want to edit some material (doing my best to keep using only uber material now in my my scenes), it takes ages to get to said materials! :(
Latest Octane plugin
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
coilbook
does vertex paint even work with octane? Thanks
neonZorglub
WhaleHunter wrote:Hi neonZorglub,
Bug:
N.
Hi WhaleHunter,
Thanks for reporting. This will be fixed in the next release.
mbetke
The little button which makes the render fit to the screen doesn't work.
It just keeps on entered production resolution and shows part of the rendering in 1:1.
Return to “Releases”
