Denoiser problem [ SOLVED ]
Moderator: JimStar
abeoctane
Hi, I am testing the Ai denoiser but I am having a problem, the denoised image came out with lot of splotches. I dont know what parameter control this, or what setting I need to use in order to eliminate the big noise with the denoiser, please help, thank you. :)
BK
abeoctane wrote:Hi, I am testing the Ai denoiser but I am having a problem, the denoised image came out with lot of splotches. I dont know what parameter control this, or what setting I need to use in order to eliminate the big noise with the denoiser, please help, thank you. :)
HI Abeoctane,
Could you please post the settings of the AI denoiser from the Imager node? also whats the samples?
Maybe faster to resolve if you share/PM me the file?
cheers
Kind Regards
bk3d
abeoctane
Hi Bk, as you said it just needed more samples, I had very few for one ligh source in a closed space, thank you very much for your help. :D
Return to “Autodesk Maya”
