My light test...
face
Next try with v5 ;)
Rendertime ~4hrs ~3900samples @ 2560x1440 pathtracing.
Rescale 75%
Each lamp has a other color emitter and a white blury specular hull.
The room has a mixed material of two glossys.
face
http://vimeo.com/user2509578
FamilyGuy
Very impressive! But 4 hours is quite a long time.
Can you share your test scene? I'd like to check something.
face
I was away, therefore 4hrs.
Maybe the render looks good at one hour...
Sure can i share the scene, hope it works.
face
room.zip
(12.16 KiB) Downloaded 318 times
radiance
with v5 this will render in at least 20 minutes i'm sure ;)
Radiance
FamilyGuy
Thanks for test scene. Could you write what software you use to reduce noise?
face
For that i don´t use any noise reduction.
face
Return to “Works In Progress”
