[AGAIN] FUMEFX 5.0.1 VDB WORK ON 3DSMAX but NOT C4D
wrapthereal66
PLEASE!
Its been several month now that i post my problem but nobody fixed it !
I can't simulate and render smoke with octane for now !
My vdb work inside of 3dsmax with octane but not on C4D ! PLEASE HELP ME.
working on one frame
And don't work into a another frame !
I attach you the vdb file ! please fix it ! i can work for now ! and i send you my problem month ago !
https://we.tl/t-RuzzJRapOy
note: everything work fine in the octane version for 3dsmax , so there is really a problem with the c4d octane version ! PLEASE.
I remember your issue! How do you use in 3dsmax? export and import as VDB? Or direct access to fumefx object from max plugin?
wrapthereal66
hello !
I export the vdb cache from fumefx then create a volume object from octane and import the vdb file that i simulate !
wrapthereal66 wrote:hello !
Could you show me the setup and parameters of VDB from 3dsmax?
wrapthereal66
this is how i setup my smoke inside of 3dsmax
wrapthereal66 wrote:this is how i setup my smoke inside of 3dsmax
I can't see vdb loader's parameters!!!
wrapthereal66
here you go !
Is this your vdb you try to load?
viewtopic.php?f=30&t=68109#p341564
wrapthereal66
nope this is a another one i simulate for exemple ! but it come from the same fumefx solver !
wrapthereal66 wrote:nope this is a another one i simulate for exemple ! but it come from the same fumefx solver !
So please send me one frame of vdb file.
