OctaneRender 2 for DAZStudio [STABLE] [OBSOLETE]
Moderator: BK
itou31
Hi Paul,
Thanks for your effort to track the bug.
Just playing more with instances and automatic generation of instances with "Surface replicate" script and cannot find a workaround.
here's an example :
You can see that iray version the grass is OK, octaner version, the grass seems to have and Y offset.
I think that creating instance one by one and replace it in the scene couls be a workaround.
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
itou31
Hi Paul,
I found it.
The "Surface replicate" script has something that is not "compatible with the plugin. The prop "grass" I use has its origin not at the base, when using joint editor, I can see green and red axes not at the base, so I should move the red and green axes to the same local Y=0 of the object. And then all instances created should be rendered at the right "altitude". If when you will work on the "instances" bug, could you check this issue also ? the "Surface replicate" script is free at ShareCG : http://www.sharecg.com/v/77603/browse/2 ... DAZ-Studio.
jodrums
btw Gtx 1060 6 GB not supported for V2 ?
i'm install V3 work fine, but on V2 GPU not Supported ?
That is correct.
jodrums
Thanks for reply Paul :)
btw can i see list V2 GPU Supported ?
or can you recomend for GTX GPU Best for V2 ?
thanks advanced .
You will need to pose this question to OTOY. However I suspect that the latest Nvidia drivers will not work with old card/Octane 2 combinations. I would strongly suggest upgrading to Octane 3.
Return to “DAZ Studio”
