OctaneRender® for 3ds max® v4.00-RC7 - 6.09 [OBSOLETE]
paride4331
SergKlyosov wrote:
paride4331 wrote:Hi SergKlyosov,
compression is on the fly, I recommend saving textures to DDS textures files.
Hi Paride,
Thank you for the reply, but didn't quite understand your answer
What is DDS files? Do I need to save textures in that format from another application like Photoshop or MARI?
Hi SergKlyosov.
https://en.wikipedia.org/wiki/DirectDraw_Surface
To save it you can do it using an image editor.
senorpablo
The compression is slow.
Why not have Octane save out a dds after it does the compression? If the file date on the compressed file is newer than the referenced texture, Octane could skip recompressing the texture every time and just load it from disk. This would save quite a bit of time.
mbetke
I got new bug. :?
Three scenes. All the same. Only one material has different colors.
I batch render the three scenes but final render got visible squares on image.
Plus the red version suddenly has no HDR loaded and flat lighting.
When I render the red color variation not with "production" but "interactive viewport" all is fine.
Denoiser and texture compression in not active in this scene. But I checked the "use denoised beauty" in preferences. Maybe the tool doesn't take into account when I disabled denoised in a scene? It should use the "beauty" pass if denoiser is off. But should use denoised beauty pass if denoiser is turned on in the scene.
PURE3D Visualisierungen
Sys: Intel Core i9-12900K, 128GB RAM, 2x 4090 RTX, Windows 11 Pro x64, 3ds Max 2024.2
paride4331
mbetke wrote:I got new bug. :?
Hi mbetke,
could you share a screenshot about Render setting, kernel type and path Tracing panel please?
paride4331
Hi senorpablo,
your idea might be interesting, I'll ask developers.
coilbook
Hi Paride,
can we finally have multi/subobject material inside the mix material since octane now support OSL?
is it possible
mbetke
Hi mbetke,
See attachment. :)
Pretty common settings. Nothing special and I use on a lot of scenes. I don't render on the network.
paride4331
Hi mbetke,
it would look like a network render issue using minize traffic, but you said do not do network render., do you have any textures on server or cloud or are you using .psd textures?
HHbomb
Hi, it seems that Render layer setup, active layer ID don't work with Movable Proxies...
[edit] : No, in fact I can't manage to use layer ID 10... It works fine with 1,2 and perhaps other ID but layer ID 10 don't work at all ( not only for proxies )
SergKlyosov
Hi senorpablo,
It will be great to have this feature
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
Return to “Releases”
