I get the installer scene from Unity, clikc Load Octane in the PBR Settings window and get those two errors:
Failed to locate cudnn64_7.dll
UnityEngine.Debug:LogError(Object)
Octane.DynamicLibrary:CheckPath()
Octane.DynamicLibrary:Load()
Octane.PluginDllLoader:LoadLibraries()
OctaneUnity.PluginController:Init()
OctaneUnity.PreferenceWindow:OnGUI()
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
I'm running Unity 2018.2.12f1, Octane version is 1.1.1.1341 Windows 10, with CUDA 10/ cuDNNIOException: Sharing violation on path C:\Users\jezrd\AppData\Local\Octane\Unity\2018.2.12f1_1.1.1.1341_T1\libfbxsdk.dll
System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean anonymous, FileOptions options) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.IO/FileStream.cs:320)
System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
(wrapper remoting-invoke-with-check) System.IO.FileStream:.ctor (string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare,int)
System.IO.File.Create (System.String path, Int32 bufferSize) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.IO/File.cs:135)
System.IO.File.Create (System.String path) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.IO/File.cs:130)
System.IO.File.WriteAllBytes (System.String path, System.Byte[] bytes) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.IO/File.cs:594)
OTOY.OctaneUnityPackage.Unpack (System.String inputFile, System.String outputDirectory)
OctaneUnity.Upgrader.DownloadCompleted (System.String file, Boolean success)
OctaneUnity.ServerClient.DownloadUpdate ()
OctaneUnity.ServerClient.Update ()
UnityEditor.EditorApplication.Internal_CallUpdateFunctions () (at C:/buildslave/unity/build/Editor/Mono/EditorApplication.cs:191)
My guess is that it can't find the cuDNN, because I have CUDA 10 installed and the path is c:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin\ not *\v9.0\bin
But ... before I start messing with installing earlier CUDA versions, what's the confirmed, working combination of Unity, Octane and CUDA/cuDNN ? The CUDA_PATH in the System Variable already points to the right folder, so maybe there's some other issue?
