Interior Uxmal
face
Looking good but i understand nothing ;)
face
http://vimeo.com/user2509578
roco
hey face well the problem is the noise in the image i need to know the final values in the scene like filtersize, maxsamples and another things to put it and have a excellent render
can you help me ?
Windows xp64 Bits, Intel i7-920, 1 GeForce GTX470 1280 mb V2+1 Gf 8600 512 mb for DISPLAY only, 12 Gb Ram DDR3 1867 Mhz, Heat Heatsink H50 water cooling, Power Supply 750 Watts, HAF 932 Full Tower, 4 Fans Cooler Master 120 mm, 28 Amp. 2600 RPM
face
Hm, i render in 2xresolution, save the image, open it in Photoshop.
Then i select the dust and scratches filter with a radius from 1 and a threshold around 100.
After that i rescale 50%.
Save the image.
You can render it in 4x too same settings and 25% resize.
I think thats the best solution, as long till the Octane MTL is working...
face
9fly
face wrote:Looking good but i understand nothing ;)
face
+2 :mrgreen:
ttaberna
kubo wrote:la versión pre 2.3_4 esta aquí http://www.refractivesoftware.com/forum ... =33&t=3517 las versión no estables o intermedias están siempre en ese foro.
Por cierto, lo de que se te cierra al poner el pathtracing yo creo que se debe a la fuente de alimentación casi seguro, te lo han comentado en algún otro post. La cosa es que en direct, la grafica casí no consume, es bastante rapida, pero en path se nota que tiene que trabajar, lo mismo prueba a ponerla como primaria (la 470) quita la otra y deja solo un disco duro, prueba entonces (creo que tenias una fuente de 750w, verdad?, si te funciona así ya sabes a buscar fuente nueva.
Brazos
I am running my gtx 460 2gb in a 450w source, no problem with pathtracing engine. I think, it could be a driver issue.
Try installing the dirvers here:http://developer.nvidia.com/object/cuda ... it_rc.html clean install.
Also if you have 2 cards, remove one and restart your computer then try only to render with this card, see what happen.
Saludos
Rampage IV Extreme+i7 3920k+2x GTX580 3GB+2x GTX470
roco
pregunta ttaberna, es misma version usas tu la del link que me proporcionas ? o de que otra parte de este foro haz bajado la version que tienes instalada en tu pc ?
saludos
ttaberna
Perdona roco pero te contesto en ingles, ya que estamos en el foro general y es por respeto al resto de usuarios no hispanoparlantes... ;)
The drivers I use are the ones in the link for windows 7 x64
I am actually using both octane pre 2.3 v4 and 2.2b stable.
The link to the pre 2.3 v4 is up in kubo's post.
BTW your image is really nice, but as the rest I think path tracer would help the realism of the mood in your scene.
Saluditos
kubo
Well, your 460 could run on solar batteries if needed :D , actually that's what I like so much about that series, the 470 and 480 are power hungry, and noisy, on the other hand the 460 is around the 2xx series on power usage but is a fermi and comes packed with tons of vram. You could probably run a 470 on a 450w PSU, but with just a HD and regular processor, but if you add a second GPU and start adding up HDs and a top notch processor a 750w won't cut it either. (Well, maybe a really really good one might)
Also taberna is right, since we are on the public forum we should stick to english for undertanding sakes, or at least, try to give a fair translation along side.
TONY JACKSON
nice job
