OctaneRender™ 4.0 for LightWave™ - Beta build 4.00.0.15 RC5
juanjgon
alperocak wrote:Hi Juanjo.
I'm getting this error.
https://drive.google.com/open?id=1wQyo4 ... 8ux_3YNw5R
I'm using win7 64bit and LW 11.6.3 64 bit.
I'm trying to install from this folder.
https://drive.google.com/open?id=1quxE5 ... FLGPkojRlG
Thanks in advance.
Do you know if the RC5 Standalone works fine on this system? If it doesn't work, you should try to update the drivers to the latest ones available, or if this doesn't fix the problem, check if the issue could be related to the Windows 7 signature issue reported here: viewtopic.php?f=25&t=66073
If the RC5 Standalone works fine, please check if you have the Visual C++ 2015 redistributable package installed on your system.
alperocak
Thanks Juanjo.
when i update win7, everythings are OK now.
Thanks again.
juanjgon
pixym wrote:This is the attached packed scene, the log file is also included.
This problem has been fixed by the core devs for the next build. Thanks for reporting it!
BorisGoreta
Store and Save commands from IPR menu take much longer then before. 10 seconds from selecting save jpg until I get a file dialog.
juanjgon
BorisGoreta wrote:Store and Save commands from IPR menu take much longer then before. 10 seconds from selecting save jpg until I get a file dialog.
Do you have the denoising enabled? Perhaps the problem is that Octane is executing the denoiser before saving the images.
promity
There is still a bug - every hundred frames Octane is turned off and my pagefile grows to indecent sizes if I use Denoiser.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
juanjgon
promity wrote:There is still a bug - every hundred frames Octane is turned off and my pagefile grows to indecent sizes if I use Denoiser.
There are several fixes in the RC6 build related to the denoiser. This one is probably the one that you have seen:
Fixed resource leak every time the denoiser is disabled and enabled again.
I'll try to release a new plugin build ASAP with this new RC6 core to test it.
promity
Yes, it seems that this is the problem. It is very interesting that when rendering, the first 50 frames in general do not affect the page file at all. But the following add one and a half gigabytes to the page file. When it reaches the size of 201 gigabytes, the render stops, Octane falls. Everytime right on the hundredth frame.
Lightwave 3d
BorisGoreta
No, denoiser is not active, even store command is slow (6 seconds).
pixym
Has somebody noticed IPR does not display anything with some "big" scenes but F9 and F10 render without issue ?
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10 64
NET RENDER : MB ASUS P9X79 - Intel i7 - Ram 16GB - Two RTX 3080 TI - Win 10 64
Return to “Lightwave 3D”
