OctaneRender for Carrara 4.05.00.09[Stable and Test]
Carrara (Integrated Plugin developed by Sighman)
Sighman
Yes and no.
You need to install a second copy of Carrara And then copy and paste the plugin. The plugin installer only recognizes a single install so you need to juggle things a bit. If you want to keep your current Carrara install at v3 then you need to
1 upgrade to v4
2 copy the v4 plugin to your second Carrara install
3 uninstall the plugin
4 reinstall v3
I really need to post a zip version of the plugin for this scenario...
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
tschwenke
Hi Simon,
Oh, ok. Thanks for the instructions. Right now, the standalone gives me to many crashes, so I guess, I'll wait a little bit and will then switch.
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
Namtar
First of all: THANK YOU SIR!!!
Will be an upgrade discount or something for Octane plugin owners when the trial ends?
Sighman
I don't know what the upgrade cost for this plugin will be, if any. If there is one it will likely be under $50. No promises.
PhilW
Looking at what Otoy have said (and again, no promises but this is what I understand) is that for individual users with up to two GPUs, Octane and some of the interface programs will become free for any users (even those without a licence currently) and those who do have an existing licence will have access to all of the interface programs - all with no upgrade cost. That sounds great to me!
rashadcarter
Sighman,
Thanks so much for this plug-in. So far so good on my end the only question I have is about the denoised view. After enabling denoising in the Render Target i do not see any option to view the Main vs Denoised versions of the render. Can you possibly point me in the right direction? Thanks, Sighman.
Sighman
rashadcarter wrote:Sighman,
You need to use render passes to see the separate channels. Under render passes there is a denoiser tab with a number of options. After enabling the passes you want you can switch between them using the drop down on the render view window.
rashadcarter
Thanks. Yes I had seen this and enabled it previously. However in the standalone version there is an option for denoised beauty. That is what I am seeking at this moment
rashadcarter
Sighman,
Apologies if my terminological usage is incorrect. What the standalone offers is a Denoised Main view. I have attached a screen shot of the standalone. This is different from the separate individual passes, at least i think they are different but please inform me if I am wrong. Thanks as always, Sighman!
View options are in green circle
Sighman
I’m not sure what the standalone does to support that. I will look into it.
Return to “Carrara”
