Version 3.08.3 (obsolete stable)
johnwilhelm wrote:
aoktar wrote:
johnwilhelm wrote: And that's the latest V4 RC right?
this one
viewtopic.php?f=85&t=68833
Great thanks a lot! I guess the installation will be the same as usual or did something change with R20? Just asking because R20 is not separately mentioned in your post...
Thank you very very much!
Same! C4D/plugins/c4doctane
stefano-dear
Hi Aoktar,
I have installed High Sierra 10.13.6 on my iMac + eGPU but the viewport movement are very slow on cinema 4D R19.068.
CUDA Driver Version: 410.130
NVIDIA web driver 387.10.10.10.40.105
To activate the eGPU I have used this script:
https://egpu.io/forums/mac-setup/script ... s-10-13-4/
Any ideas?
Best Regards
Stefano
stefano-dear wrote:Hi Aoktar,
Any ideas?
Best Regards
Stefano
You may try different versions of OS and C4D. Also try without eGPU. I don't have much ideas.
tomsvfx
Hi Aoktar, when there is plan to release update for 3.08.4 core update?
viewtopic.php?f=24&t=68902
I understand that there is some hassles with R20 release, but is it possible to release 3.08.4 update for customers who use R15-R19 in production?
As I know, you have fixed couple C4D plugin bugs that I and other users had reported for this release, for whom have postponed release for some time already due to R20 plugin updates.
Thanks in advance,
Tom
tomsvfx wrote:Hi Aoktar, when there is plan to release update for 3.08.4 core update?
Thanks in advance,
Tom
When I finished the current revisions It will be possible. I hope soon!
tomsvfx
Thanks for the answer.
Soon - might be next week or a bit later?
stefano-dear
Any ideas?
Best Regards
Stefano
Try different OS and C4D?!? I have to reinstall all the software all day? Sorry but it's unacceptable.... if it's a stable release it has to work, I'm not a beta tester!
tomsvfx
You are working on a system that does not directly support CUDA rendering, so its anyway like beeing a beta tester.
eGPU for macOS has te be setup in a very specific way to work good and its not possible with all of the Appple computers because of the port speed. Couple of my colleagues had tried this and it was not possible because of Apple hardware to get smooth results.
eGPU is good when you are just doing pure rendering, but it gets slow for interactive things.
thanulee
Hi, i have an issue with motion blur. When i activate it from camera tag, c4d freezes. I can send specific scene but since its ongoing project i can only pm it. Is there a way to do this? thanks
thanulee wrote:Hi, i have an issue with motion blur. When i activate it from camera tag, c4d freezes. I can send specific scene but since its ongoing project i can only pm it. Is there a way to do this? thanks
try to find what's causing that in your scene
Return to “Releases”
