Version 4.0-RC4-R2 (obsolete release candidate) 22.09.201
Hi All,
This is next test/preview release of plugin which is based on V4-RC4 SDK. We recommend that you mention that it is experimental, they should not use it for production work, and that we cannot guarantee backward compatibility.
Please note that this build will expire in 60 days, this is now shown on the bottom right of the standalone release.
Whilst we have reached the feature lock milestone, we consider this a non-stable release, as we expect to stabilise in preparation for the first stable. Until then, please do not use this for production purposes.
EDIT: There have been various reports that the Linux and OSX builds crash during startup after the cuDNN library got downloaded and installed. We hope to have found and fixed the issue and updated the OSX and Linux release builds accordingly.
Please see this thread for V4 features: viewtopic.php?f=33&t=66013
This is matching Standalone V4-RC4: [url=viewtopic.php?f=33&t=68770[/url]
Important notes:
Since XB2 Preview, we have dropped support for Fermi cards.
Network render is still disabled.
Denoiser is under Camera Imager from Settings or Camera Tags. Just denoised beauty pass is available in plugin, others will be added.
Changes of RC4
- Improvements on OslTexture interface
- Default environment color is now part of scene parameters
- R20 build (Not available yet for OSX version)
- Light linking invert
Changes of V4-RC2-R1
- Fix: several fixes on missing ui stuff in sub_material and universal material
- Fix: Wrong ids for denoising passes, added volume denoising passes
Changes of V4-RC1.0
- Fix: Error on denoising devices
- New 1/IOR map in universal material
- ImageTexture compression added and channel format fixed
- Fix: Delete material problem while NE open
- AI volume denoiser
- Fix: Picture viewer rendering problems with denoiser and passes
- New pins added in Universal material.
- Additionally some minor fixes in plugin...
Changes of V4-XB3
- Help support for the Nodes in Node Editor
- Geometry Engine default changed to "All Movable"
- Visualisation for VDB voxels
Changes of V4-XB2.1 test2
- Fixed random material preview crashes, mostly on LiveDb
- Fix: error on OSX and reading of ScatterObject/csv files
- Added: New universal material to Octane Material and Blend material
- New options in Instance Color and XP emitter
Addons for plugin side
- Viewport rendering: Activate from Live Viewer/Octane dialog options menu. Keep open the one of these windows during the render session.
- Node Editor: Experimental float sliders on nodes. Need to activate from "settings->nodes->embedded gui".
- Node Editor: Show/hide options for node pins.
- New help system, updated manual(it's still wip). Access by help icons from nodes/etc..
- Several minor fixes.
WINDOWS REGULAR BUILD
https://render.otoy.com/customerdownloa ... R2-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD
OSX REGULAR BUILD
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053). Otherwise the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers(most recents like 39x.x) with Cuda 9.1 - change driver versions if you have much trouble with current driver
HELP MANUAL
Use embedded help buttons from Octane nodes and windows
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Node sliders
https://vimeo.com/268974364
Viewport rendering mode
https://vimeo.com/265747658
https://vimeo.com/265294205
mesut
this opacity/shadow - problem still exists in this release:
viewtopic.php?f=85&t=68537&p=346246#p346245
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
stefano-dear
Hi Aoktar,
on my computer this release crash immediately on C4D startup.
EDIT: the crash it's caused by the network render. If I disable the slave, it works!
MAC 10.12.6 + GTX 1080Ti - Driver NVIDIA 387.178
SLAVE Win 10 + 3x GTX 1080Ti + 2x GTX 980Ti - Driver NVIDIA 399.24
C4D R19.068
_BugReport.zip
(85.82 KiB) Downloaded 402 times
pxlntwrk
Thanks for this release !!
pxlntwrk.net
mesut
mesut wrote:this opacity/shadow - problem still exists in this release:
it seems that the opacity/shadow issue only occurs when the dirt node is used in the opacity slot. both, directly and as a e.g. amount-source being fed into a mixteture-node.
this issue does not occur, when dirt-node is not used. noise or rgb won't produce this error.
have tested this dirtnode/opacity/shadow-issue with different versions now:
r18 + 3.06.02 -> shadow is not being cast at all.
r19 + 3.08.3 -> shadow is being cast in the faulty way as shown.
r20 + most recent v4-release -> shadow is being cast in the faulty way as shown.
EOA
That help link in the program gives a 404 file not found error
- is there anywhere one can find a sort of a introductory guide to the universal material btw?
3dworks
stefano-dear wrote:Hi Aoktar,
C4D R19.068
probably the same problem as i had with LW plugin. seems the latest version is working well only without networking on a single mac.
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
stefano-dear
C4D R19.068
Yes, but it's normal because the network render is not enabled
Important notes:
3dworks
C4D R19.068
Important notes:
ah sorry didn't know, this seems to be specific to C4D plugin, which i am not following closely. i was fooled be the "RC" versioning, which is supposed to have all release features active. in any case, the standalone and the LW plugin are enabled for network.
pxlntwrk wrote:Thanks for this release !!
Thanks for your kindness!
Return to “Releases”
