OctaneRender 3 for Rhino (OBSOLETE)
I have added the Studio (Subscription) build of the Octane 4 test build plugin to the top of this thread.
fabrizio_s
Thank you!!!
BTW. is it possible to have 3.08 and 4 installed in the same time? Or v4 installation overwrite the 3.08?
bye
The 3.08 and 4.00 plugins have the same plugin Id, so the most recently installed will overwrite the previous version.
maray29
Hi Paul,
Does the 4.00.0.96 version work with Rhino 5? I tried with SR14 latest release and I cannot install because it says that the package is not compatible with the Rhino Installer Engine.
Edit: Didn't notice that 4.00 is only for Rhino 6.
neiwei845458454
Hi Paul,
I have use the Rhino5, because Rhino v6 have more plugins for modeling dont used and more bugs. So I will often use the Rhino5.
Can you make the V4 plugin for Rhinov5?
I really need the Rhino5 to work with my jobs.
Thank you for your support.
Best,
A.
I have updated the Rhino5 TEST installers to fix the material slider issue, and also added Rhino5 plugin installers for Octane 4.
neiwei845458454
OKay, Thanks
Nice job.
Refracty
Hello Paul,
I have just checked if the problem of missing shader attributes (like diffuse color) in Viewport and on preview ball is still present in Rhino6.
Still I can not see the material color in the viewport.
When will that be fixed? Is it a problem of the Rhino builds?
I am using 3.08.3.95 Plugin with Rhino 6SR8 on Windows10
Thank you
face_off wrote:
Refracty wrote:Hi Paul,
at the moment the textures / materials are not displayed correctly in the Rhino-Viewport as far as I know.
When will it be possible to have a correct preview of materials in Rhino?
Thank you
Nando
Can you tell me which version of Rhino and the plug-in you are using, and provide screenshots of the problem.
fabrizio_s
maybe I'm saying something stupid...but have you check which render engine is active? Please, look at this screenshot; it looks like your issue.
bye
fabrizio_s
Hi Paul,
I'm trying v4. I can't see materials previews
bye
Return to “Rhinoceros 3D”
