OctaneRender 3 for AutoCAD [OBSOLETE]
Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
guillerodriguezv
Thank you Paul, I will give it a try.
Guillermo
Laptop- Win 10 64- 32 Gig GTX 880m 8 Gig - Desktop Win 10 64- 16 Gig GTX 980 ti 8 Gig
guillerodriguezv
1st error window
1st error window
Hi Paul, I just check the new Octane plugin in Autocad 2019 and It could not load. I attach some pics.
2nd error window
2nd error window
Hi Guillermo
My apologies for missing your post.
Does the AutoCAD 2018 version of this same build work for you pls?
Does Octane Standalone 3.08.3 work for you?
guillerodriguezv
Hi Paul,
sorry for being late too. :roll:
1 - For Autocad 2018 the plugin´s version is 3.7.0.22 (64 bit) that you uploaded , it is a different version from 2019 (3.08.1.23), but works fine.
2 - Yes works fine (Octane Standalone 3.08.3)
regards
Guillermo R.
I will do an Octane 3.08.3 build by the end of the week, which will hopefully fix your issue. Sorry for the delay.
Guillermo, can you tell me if this installer works for you pls?
https://render.otoy.com/customerdownloa ... _64bit.exe
guillerodriguezv
Hi Paul, sorry for this late reply.
Now the 2019 plugin works fine (at least it loads); ACAD 2019 loads the plugin but it only render simple geometry, when you try to render more complex geometry it fails to load. In ACAD 2018 plugin load perfectly. I had attached some sample pics.
Autocad 2018
Autocad 2018
Autocad 2019
Autocad 2019
This looks like a bug in AutoCAD. acbr22.dbx mention in the error does not exist with AutoCAD 2019 - only for AutoCAD 2018. Can you pls send me a scene which produces this error?
guillerodriguezv
Hi Paul, I just uploaded the Autocad tested file.
Guillermo R.
ACAD-GRV HOUSE OCT 2018.7z
Autocad testing file
(18.46 MiB) Downloaded 780 times
I have updated the STABLE build at the top of this thread with:
3.08.5.25 (18-Oct-2018)
- Compiled with Octane 3.08.5
- Fixed AutoCAD 2019 exception
Return to “Autodesk AutoCAD”
