I have updated the TEST installers at the top of this thread with:
3.08.3.93
- Compiled with Octane 3.08.3
- Fixed error in the Rhino6 build which resulted in proxy materials being loaded twice
- Fixed exception when loading a LiveDb material when the OctaneRender panel was not visible
- NOTE: LiveDb materials containing OSL nodes will not load into the plugin correctly, as the plugin does not currently support OSL Projection or Texture nodes. Instead, copy these materials into the clipboard from Octane Standalone and paste them into a NodeGraph material in the plugin
Pls note the second line item above is a critical issue for Rhino6 users using OBJ proxies, so if you are one of these users, pls update to this version ASAP.
OctaneRender 3 for Rhino (OBSOLETE)
I have updated the Rhino6 TEST installers at the top of this thread with:
3.08.3.94
- Fixed critical Rhino6 plugin error where the Live Geometry settings for meshes were not being loaded when opening a .3dm file
3.08.3.94
3.08.3.95
- Fixed issue in Rhino6 where sometimes the Viewport would open under the Rhino window
- Further fix to the Rhino6 plugin where the Live Geometry settings for meshes were not being loaded when opening a .3dm file
- Fixed issue where some LiveDb materials were not loading
Franchais, can you pls try the above version, and let me know if you continue to have problems.
3.08.3.95
I have added an Octane 4 build of the plugin for testing at the top of this thread. Do not save scenes with this version if you will then need to open them with the Octane 3 version of the plugin.
4.00.0.96
- Compiled with Octane 4.00 RC4
- Changed Devices tab to use the Octane API panel
- Added Denoiser options in the Imager settings
- Added Denoised Beauty pass to the Select Render Pass combobox on the Viewport toolbar
- Added Kernel AI Light options
- Added RenderPasses Denoiser passes
- Fixed pause state being lost when restarting a completed render
4.00.0.96
- fabrizio_s
Hi Paul,
is this version for subscription?
bye
bye
I have not done a subscription version yet - but will put one together in the next few days.is this version for subscription?
