OctaneRender™ 4 RC 2
Renart
Why not render them in different passes? One render for the background and one render for the character with environment visibility off. This is how we do usually...
FrankPooleFloating
^ True dat. Whenever anything comes up that is an oddity (and likely pretty rare), and can be fixed with something like render layers, its just so much easier to bang out that workaround and get on with your life.. imho. Prolly would have taken less time than the post. ;)
haze
Ideally we would shift the ray epsilon to the geometry nodes, but that would come at a (possibly large) render performance cost. We'll look into it and see if there is another way.
coilbook
Thanks all for all your help.
We just didn't want to deal with layers. . Maybe otoy will come up with something one day, for example, a custom ray epsilon value per object (in object properties) for just that one problematic object. I guess that's what you meant talking about shifting it to the geometry node?
paride4331
coilbook wrote:1. Please add an option where a final image sequence is a DENOISED BEAUTY only.
Currently we added denoised beauty in the render elements but we constantly have to delete beauty pass that is also saved during rendering
2. There is still a bug when expected exposure is set to like 1.5 and not 1, 2, 3, it is stuck for a while at 1 samples/s
Hi coilbook,
this option will be with next 3dsMax plugin release,
Renart
This build is great and the future looks very promising!
But one small thing really bother me sometimes, it's the gizmo tool not being properly screen based.
What I mean is, sometime in big scale, it becomes very painful to move object around and we have to drag the gizmo multiple time to get the object where we want. Like if the position of the mouse on the screen doesn't really represent how far a object will move. Also the scale option is very sensible sometimes and I end up with very high or very low values.
Any plan on improving that?
WIPEXPO
Hi i have noticed denoiser does not affect shadows generated by shadow catcher (grainy) is that ment to be ?
BorisGoreta
Can't mix 980Ti and 1080 with the latest Nvidia drivers. Had to go back to 23.21.13.8871 and then it works.
coilbook
empty scene uses 1.2 gb octane 3ds max
haze
coilbook wrote:empty scene uses 1.2 gb octane 3ds max
What is your Parallel Samples setting? If mine is set to 1, then Octane uses 51.3MB for an empty scene. If I set it to the new max of 32, then it'll use roughly 32 times that ie around 1400MB. If you have enough VRAM, increasing parallel samples helps render speed. If you don't have a lot, then you should use 8 or 16.
