Version 3.08.3 (obsolete stable)
Weezer
Just trying out 3.08.3 on MacOS, R19. I seem to get crashes if I ask Octane to convert materials and then render them. Enclosed is the bug report. I was playing with some Forester plant instances and a high-res displacement map – nothing really too taxing.
_BugReport.txt
(498.18 KiB) Downloaded 300 times
Weezer
Another crash. It was working quite happily, then I moved an object by mistake and it crashed. I had a Speedtree model (50MB including textures), with some large texture maps on a plane (another 100MB I guess), so it's not a massively heavy scene for my 6GB GPU.
R19, MacSO 10.13.6, latest CUDA drivers etc. It's this kind thing that plagues the Mac version all the time...
_BugReport.txt
(608.33 KiB) Downloaded 277 times
Weezer wrote:Another crash. It was working quite happily, then I moved an object by mistake and it crashed. I had a Speedtree model (50MB including textures), with some large texture maps on a plane (another 100MB I guess), so it's not a massively heavy scene for my 6GB GPU.
Please capture a video to show what you do and send me your scene. Thanks!
Weezer
Okay, will have to do it after the weekend. I've no idea how long it will take – sometimes it works for ages before crashing!
thanulee
Why editor doesnt show the texture? opened closed file many times, restarted c4d. Also in order to see its preview in materials down i need to open a window and double click it otherwise its black there as well
thanulee wrote:Why editor doesnt show the texture? opened closed file many times, restarted c4d. Also in order to see its preview in materials down i need to open a window and double click it otherwise its black there as well
Which editor? You need active render in LiveViewer for full functionality of node editor previews. Could you confirm?
thanulee
Yes, confirmed, thanks a lot, I didnt know this new behavior. So only when live viewer is open i can see what i do in node editor previews?
thanulee wrote:Yes, confirmed, thanks a lot, I didnt know this new behavior. So only when live viewer is open i can see what i do in node editor previews?
In generaly yes. You need LV render.
tomsvfx
What is wrong with the edge sampling when using Render Layers? The problem is very big, since I use a lot of Render Layers in my workflow and where I work and having this issue is very sad. That might be problem with Octane Core?
When using Render layers edge sampling is completly messed up.
In beauty its all ok, but when using any pass (anythong from beauty pass or rende layer pass) edges of objects are glitched.
Here is examples images and video:
Video:
Main/Beauty:
Diffuse pass:
thanulee
Maybe its just the LV preview and PV render is fine. Did u try that? Just testing out myself these days 3.08 so i wouldnt know much to help sorry.
Return to “Releases”
