OctaneRender® for 3ds max® v3.08.2 - 5.12 [OBSOLETE]
mbetke
Hi mbetke,
I suppose it depends on different Response Gamma LUT system in Octane SDK setup.
You should manually re-enter your LUT setup in Octane camera imager or in Octane render setup camera tab.
Why is this? I have hunderds of scenes with slight variations in constuctions for a web configurator. They have to be coherent in the look. So if my client wants additional 200+ images with a new configuraion you tell me I have to re-ente all by hand? Stable plugins should not vary in the overall look of the scenes....
PURE3D Visualisierungen
paride4331
Hi mbetke,
Could you kindle share to me (in PM) a scene with your issue, I'll take a look.
lunarstudio
Not sure if these errors should be reported to the bug reports section although this is more beta specific.
Trying to enable network rendering which was working fine before (previous beta versions.)
Same base Octane installed on both machines.
Receiving error message:
"Daemon startup script does not exist. Please install the daemon first."
I have repeatedly installed the daemon but still receive this message when trying to start it.
***UPDATE RESOLVED***: Bitdefender was marking your startup script for installing the DAEMON under the startup folder as a virus. In particular, it flags this file as an Atc4.Detection.CMD virus. I personally don't know enough about viruses to know if this is or isn't, but for now I've temporarily excluded this file.
coilbook
Can anyone from otoy tell me what am I supposed to do and how to finish this project. There is a clearly a visible border when using Octane Sun with Volume and PHoenix Grid VDB (rendering with AO mode )
paride4331
coilbook wrote:Can anyone from otoy tell me what am I supposed to do and how to finish this project. There is a clearly a visible border when using Octane Sun with Volume and PHoenix Grid VDB (rendering with AO mode )
Hi coilbook,
it remembers .vdb overlapping issue.
Could you send me your phoenix file?
coilbook
Hi Paride
I sent it to you PM. Thank you!
coilbook
Paride[/quote]
Also just isolating the sun with volume and grid box you can clearly see the problem
UPDATE:
it looks like 3.08 5.07 works fine. So there is something otoy did in the newest releases. And it loads faster
coilbook
Hi coilbook,
Hi Paride,
when you report this bug can you also tell them about octane not loading phoenix during rendering Thanks
Return to “Releases”
