thanks. but both screens connected to 1080. Win7. So AE use only this gpu. Its just 4 millions polygons. Its not 20, or 100 million. Why cycles or redshift works without problem? In same time with AE too.bepeg4d wrote:Hi max1e,
sorry, I’m not an AE user, do I really don’t understand your ‘video-question’.
Please, note that 970 has only 3.5GB of VRAM, even less under Win 10, if you use both GPUs, the available VRAM is limited to ~3GB, and if you work in the same time with AE, the available VRAM is even less.
If you want to work with both AE and c4doctane at the same time, try this setup:In this way, you should be able to work with both applications, with better stability.
- connect 970 to display so it will be used also for system/OpenGL, and use it also with AE and all the other applications, Photoshop, Chrome ecc. (you can define this in the Nvidia control panel)
 - use the 1080 with c4doctane - CUDA rendering only to have the maximum available VRAM
ciao beppe
*edit: in v4 you can also use 970 for AI Denoising, and 1080 for rendering only.
I will try connect 970 to screens, but on this way viewport c4d have less performance. Its very strange, only 4 millions poly.
