ANIMATION IN OCTANE STANDALONE
magierski
Hi
Maybe it is a stupid question but how can I render the animation in Octane Standalone.
I've export the orbx file with the animation from modo, opened it in Octane Standalone. I can see the timeline etc.
But how can I export this 10 frames animation with other passes seleceted?
Goldorak
Have you tried using the render job nodes in 3.06 to set up a batch render of the frames you need to generate? the RJ nodes can allow you to set in/out frames for output. You can also run Octane in CLI mode which gives you a way to run render jobs from command line/batch scripts.
Uhlhorn
You have to use a command in Modo: octane.saveAnimation
(Perhaps in an newer version it is not longer necessary.)
linograndi
If you exported your animation in STandAlone using the ORBX format, just select the Batch Rendering option in the Script menu.
Uhlhorn
I tried it just with version 3.07. You have to use the command above to get an Octane file with a time line. In the Modo model tab there is an input form for commends in the lower right.
