in LW 2018 we try octane Render V4.0 beta but impossible to load an image texture.
The Octane Texture Image Node don't open. When i clic on, nothing happens.
Any suggestions ?
OctaneRender™ 4.0 for LightWave™ - Beta build 4.00.0.8 XB3
Are you working with LightWave 2018.0.4 or 2018.0.5? The plugin is only compatible with these latest LightWave builds. If this is not your problem, please try to install the plugin again, adding it to the Layout after removing the Octane master plugin from the master plugins panel.scaphoide wrote:Hi,
Any suggestions ?
Hello,
with fiberfx + win10 + lw2018-64+octane XB3, the fiber-fx settings are automaticaly updating with IPR only when a LW2018 VPR is active or when surface-preview rendering (vpr too so) is active : when lightwave displays only OPENGL windows, IPR doesn't update FFX changes & need to reload fully (of course wirh FFX auto-update option enabled) : is it normal ?
- BorisGoreta
- Contact:
Yeah this is normal. If you see fibers in OpenGL preview then fibers will automatically update in IPR, if you disable OpenGl preview then it will not update. This is very handy since you can decide weather you wish it to update or not.
vipvip wrote:Hello,
OK thanks, good tip, i didn't know !BorisGoreta wrote:Yeah this is normal. If you see fibers in OpenGL preview then fibers will automatically update in IPR, if you disable OpenGl preview then it will not update. This is very handy since you can decide weather you wish it to update or not.
Just received my second GTX 1080 TI today and WOW… No more thing to write
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
Am I missing something or just denoising does not work with Render Region ?
I have an odd issue, Instances does not render ;-(
Has somebody noticed that ?
- BorderLine
No problem here !pixym wrote:I have an odd issue, Instances does not render ;-(
