AI Denoiser only works for single frame render
Unity Integrated Plugin (Integrated Plugin maintained by OTOY)
Moderator: ChrisHekman
JimBob
Hi all,
I have been trying to render an image sequence with AI Denoiser enabled. Each frame is exported as a PNG for the standard Beauty pass and another PNG for the Beauty Denoised pass. The first denoised frame comes out as expected but every frame after that looks like the denoise has not worked. I have tried changing the frame interval and also time interval settings so that the first rendered frame is actually a different Unity frame and the same issue occurs. Also tried changing number of samples but can't get it to work.
Seems like a bug but just wondering if anyone else has experienced anything similar or found a workaround?
Cheers,
J
Xhed
Thanks for notifying us of the issue. We'll look into it.
- Rick
JimBob
Hi Xhed,
Just wondering if your team got a chance to look into this bug? If so, any timescale on a fix?
It would be great to get using the feature properly soon.
Best wishes,
J
ChrisHekman
The issue has been found and fixed and will be part of the next build. (We do not have a date for the next build yet)
JimBob
Good to hear! I will look forward to the update!
J
Return to “Unity”
