Version 3.08.1-R4 (obsolete stable)
I download the install today from this thread. 388.13 drivers here. I ll try newer ones to see.. thanks
Drivers latest update renders an empty scene now. When i add multicloner crashes on first frame. Scene attached:
https://www.dropbox.com/s/jf85r2mm2eu16 ... 8.c4d?dl=0
Please re-download plugin from first page. Forester crashes should be fixed. Let me know!thanulee wrote:Drivers latest update renders an empty scene now. When i add multicloner crashes on first frame. Scene attached:
Just did again and it keeps crashing on forester. I only have the basic forester tree, with octane scatter.
What's your forester version? I'll send you a pmthanulee wrote:Just did again and it keeps crashing on forester. I only have the basic forester tree, with octane scatter.
Hey Ahmet, the version u send me last night, works with network rendering? thanks bud
R3 is uploaded for fixing this.pxlntwrk wrote:I think I already had this version, but I reinstalled it,
it's exactly the same, on 4 gpu only 3 work when i launch render in picture viewer or with deadline.
Hi there,
We have a system going with 7 x 1080 ti’s We keep getting cuda errors on larger frame sequences. We’ve tried multiple nvidia drivers on c4d R18.057 on octane version 3.08.1 R3.
Whats the most stable driver combined with octane 3.08 we can use? how do we fix this issue?
Thanks for helping.
Thanks for helping.
aoktar wrote: Changes of Version 3.08.1-R3
- OSL texture: Projection input support.
Thank you Ahmet. I can confirm that projections are finally working!
Is there a chance to see the fix from V4-XB3-R1 for material previews in 3.08.1? The C4D scene from this post is still causing Cuda error 700 after frame 5 in 3.08.1 R3 when material previews are enabled.
About other input metadata options:
I noticed that
label and description don't work. I also noticed that using slidermin and slidermax used to work, but it doesn't work anymore. All of those would be very helpful in making OSL scripts much more user friendly.Regards
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
