Hi following up a tutorial, i try setup this "../../RENDERS/TEST_RENDERS/$prj_" .
From c4d save menu, it goes 2 folders up and saves to the proper directory.
Octane's render passes though, does nothing. If i dont write "../.." and define the path manually, then token works.
Im on 3.07 stable. Any tips?
cheers
Tokens question
Tokens should work but passes will not support relative paths. Btw always try with latest stables when you have issues.
Mmmm. Would be nice if there was support for this on passes.
I tried and i ve posted that i cant render sequences at all with 3.08 latest in R18. I ve attached the bug report as well etc. Plz take a look, cause i cant upgrade. Thanks
I don't have backward support from latest versions. You should post your scenes and detailed information about problems. So I can help you.thanulee wrote:Mmmm. Would be nice if there was support for this on passes.
- mikeadamwood
I've just been banging my head against a wall trying to get this to work wondering why it's wasn't, I assumed Cinema would just translate the variables on scene export to absolute references based on document?
I'd love support for this, it really was a game changer for me when I found token system, gutted octane multi-pass doesn't work with it
Windows 11 Pro | ASUS Pro WSX80E | AMD Threadripper Pro 5975WX 32-Core | 256GB Micron 8x32GB 3200MHz ECC | 2x PNY RTX6000 ADA
+ 1
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, 4x EVGA GTX 1080Ti, Octane-for-C4D 4.x.x, Nvidia 398.82
- proundkontra
- Contact:
+1
nikoeriksson.ch| i7 6x3.5 Ghz | 64GB | 2 x GTX 1080Ti Hybrid , 1x GTX 980Ti Hybrid | Win 10 | C4D R19.068 | Octane Render Plugin C4D v3.08.4
I'll send you a test build before making public release. Could you please check relative paths with tokens in render passes?
Tested new build, it works as expected (i pmed u Aoktar in case u havent seen it). Thanks alot!!
You first as I expected;) Please let me know any problems so I can sort before doing releasethanulee wrote:Tested new build, it works as expected (i pmed u Aoktar in case u havent seen it). Thanks alot!!
