Version 4 - XB3-R1 (Experimental)
NC17z
Hi Everyone,
Is there a way to render one pass using the Ai Denoiser? I'm talking about one image per frame as a Tiff or a PNG without it being Multi Layer Beauty and Beauty Denoised.
I just want my system to render one pass using the Ai Denoiser. I don't want it to do twice the work, if you know what I mean.
Thanks in advance for any assistance in this matter,
Lenny
lucioing
NC17z wrote:Hi Everyone,
Lenny
It's my problem too... :o
Plus, maybe, I do something wrong... But, the denoised image, seems to be much much saturated than the regular image, as shown in the picture...
I'm sorry, to post this that sounds stupid, but maybe, I missed some info about it.
Thank you.
L.
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
Lenny
Thank you.
L.
It's a render pass and color profile is like what you set in render settings. Linear by default, so you see like that. Please apply gamma correction or just switch to tonemapped as in Live Viewer.
lucioing
Thank you, Ahmet (TheGreat)!
L.
Fake Pilot
When using the Viewport Render, I cannot make any changes to parameters. They jump back to whatever they had before.
Have to pause it every time I want to make a change. Is this a bug or is there a work around?
Machine: Macbook Pro M4 Max, 128GB.
Fake Pilot wrote:When using the Viewport Render, I cannot make any changes to parameters. They jump back to whatever they had before.
Thanks! It actually has been reported! Viewport rendering is an experimental feature. It means that's not perfectly done, just for gathering some feedback. I have to find some ways to fix these problems.
Fake Pilot
OK!
I guess my work-around is having a hotkey for Autokeying. When it's on, you can change parameters.
You just have to remove keyframes when you don't want them.
Reason why I think this is sooo useful, it's the only way I have found to see real time cel shading in C4D, in the viewport.
Prorender works in viewport, but does not support its own art cel shader or even luminance cel shader trick. Does not pick up lights.
Could use the Interactive Viewport rendering, but it's much slower than Octane. You can't play the timeline and see how it will look.
eyeonestudio
OpenVBD Loader : Bounding Box is not update.... :?
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
eyeonestudio wrote:OpenVBD Loader : Bounding Box is not update.... :?
Change units :?
tim_grove
Anybody able to replicate those 700 Errors on the scene I shared?
Return to “Releases”
