Hi!
This is the first beta build of the OctaneRender™ 4.0 for Houdini™ plugin compiled with the Octane 4.00 XB3 core. This release is available for the Houdini 15.5/16.0/16.5 latest production builds on Windows x64, Linux gcc4.8 and OSX 10.11. This plugin is also compatible with Houdini 15.5/16.0/16.5 Indie. In this case, the plugin will have a 4k limited resolution while rendering sequences, and the scene export and cloud rendering features disabled.
As with all experimental and test releases, please do not use this build for production work, and please note that we still classify this as an experimental release.
Important notes:
- NVIDIA Driver version 387 or higher is required on Windows and Linux, and any CUDA driver for Mac should work that supports CUDA 9.1.
- Octane no longer supports Fermi GPUs.
- We are still working through a lot of changes required to make Network Render operational. This is directly related to AI Scene and AI Light.
- AI Denoiser will not denoise volumes and hairs yet.
This plugin build has these Octane 4 features available:
- Denoiser options in the Imager node.
- Several new denoised passes in the Passes node.
- Denoiser device options in the plugin options panel, GPUs tab.
- New "Show Denoise" button in the OpenGL IPR window to swicth on/off the denoised beauty pass.
- New "Octane_IPR_showDenoise" hscript command to control the IPR denoised beauty pass show state.
- AI Lights options in the kernel nodes.
- AI Scene and Out of core geometry improvements (no new options to control these features yet).
- New option in the kernels to set the toon shading ambient light.
- Support for the "cast shadows" feature in the toon lights.
- New Nishita daylight model.
- New "Universal" material node.
- New "Planetary" environment node.
For introductory material on V4, please see the first release post of V4
Release 4.00.0.8 regular license
Houdini 15.5 Windows Houdini 16.0 Windows Houdini 16.5 Windows
Houdini 15.5/16.0/16.5 Linux
Houdini 16.0/16.5 OSX
Release 4.00.0.8 subscription license
Enjoy it!
OctaneRender™ 4.0 for Houdini™ - beta build 4.00.0.8 XB3
Thanks Juanjo!
Intel i7 930 2.8 GHz | 24 GB | GeForce GTX 980 Ti, 6 GB | Windows 7 Pro 64-bit | Houdini FX 17.5 | http://techie.se
Love your work Juanjgon, one question and it's probably just me beeing confused but are plugins going to be free with v4 ? because I dont own this plugin yet..should I just get it or wait ?
