Hi all,
i am trying to establish a workflow from Octane standalone to Unity for VR use.
When importing an ORBX file to Unity I get this Error:
GUI Error: You are pushing more GUIClips than you are popping. Make sure they are balanced)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
The import results in an asset, that seems to be nothing but a gizmo when selected from the Hierarchy panel.
No geometry is shown in the viewport.
My guess what could be causing this error is the following:
Due to a Paypal payment issue in Germany I cannot use a subsrciption license, which is, as far as I know, required for running Octane in Unity.
My company does own several pre-paid Octane licenses which are running fine in Octane standalone.
I was able to load Octane in Unity using the Unity Account as the Login Account in the Octane settings.
The Octane log shows the following:
Started logging on 21.06.18 09:05:55
OctaneRender Prime 4.00 XB3 (4000008)
ORC user subscription status could not be retrieved: The server returned a client-side error with HTTP code: 401
ORC subscription status cannot be found
I have contacted the Octane support about the paypal payment issue in Germany, but I did not recieve a response so far.
Does someone know if this is truely a licensing issue, or is it something that i cat fix in another way?
With best regards,
Yskert
ORBX Import Problem
Moderator: ChrisHekman
Are there log messages in your Unity Console window before the last one?
Could you also provide me with a copy of the last error message which contains the callstack? (can also be found in the Console window).
- Rick
Good morning,
thank you for your reply!
I just did a fresh startup, loaded Octane: The Octane log shows the same error as yesterday.
I tried the ORBX import again, there are 3 initial errors that keep repeating in the same order every few minutes without me doing anything.
The attached images show the 3 error messages.
Thank you for your help!
Can you try placing the ORBX file you're importing in the somewhere in the Assets folder for your project? I reckon it'll work then. We'll work on a fix in the meantime to allow ORBX files to be loaded from other locations.
- Rick
that fixed the import errors, thank you!
Unfortunately there is still nothing more than a gizmo when I drag and drop the import to the viewport.
It looks just like in the first image I posted. I double checked my file, and I am sure it actually contains geometry.
Any idea what could still be the issue?
With best regards,
Yskert
With best regards,
Yskert
