OctaneRender 3 for Rhino (OBSOLETE)
Is it the maximum level of float numbers, int numbers or both?
Also - what exact version have you installed pls?
fabrizio_s
Hi Paul,
I have installed the last version of rhino 6 (SR5) and the last version of octane (OctaneRender for Rhino6 3.08.1.92 (64 bit) SUBSCRIPTION).
Please, take a look at this video I made:
http://s000.tinyupload.com/index.php?fi ... 6916299755
bye
fabrizio_s
And there is the preview command hides from the menu of the right mouse button
http://s000.tinyupload.com/index.php?fi ... 7966468833
bye
It looks like it is only with certain pins. Can you pls tell me exactly which pins it is happening with?
That Preview menu item should not be there, and I will remove it from the next release.
fabrizio_s
Hi Paul,
the issue is absolutely random.
bye
I have updated the TEST installers for Rhino6 at the top of this thread to resolve this issue.
fabrizio_s
hi Paul and thanks for the new version of the plugin.
It is close to perfection. There is only one case that has a little problem but it is solvable clicking on another parameter. Please, take a look at this video.
http://s000.tinyupload.com/index.php?fi ... 1148297567
bye
fabrizio
fabrizio_s
BTW,
why if I change anisotropy nothing change? What am I doing wrong?
bye
If the panel is too narrow, there are going to be issues sizing the controls, which you are seeing in that video. So keep the panel at a reasonable width.
This is a general Octane question - so I suggest reading the latest Octane Standalone manual, and if it does not cover your problem, post in the Octane Standalone forum.
fabrizio_s
ok thanx
Return to “Rhinoceros 3D”
