richardyarlett wrote:Hi neonZorglub
Yes that fixed number 1) issue. I did not know you had moved this option away from the main area. So that is good.
For the UVW map crash....... yes it ONLY happens with this one modifier as best as I have found. It crashes completely, whether it is a brand new scene with just one object, or a really complex scene. Makes no difference.
Hi richardyarlett,
For 1), nice to see that it solved the problem.
For the crash, as we can't reproduce it, I guess it's not from Octane .. It seems to happen while editing your object (delete / re add this modifier) , and hopefully not while loading a scene containing this modifer .. so a work around is to save your scene on each step, and avoid delete / add once your material are set..
Note: the network rendering is currently disabled for V4, it's still a work in progress.. XB is eXperimental build, not all features are supposed to be implemented ..
