OctaneRender 3 for Rhino (OBSOLETE)
I tried to install the last version of octane for rhino 6. I have some trouble with slider and values of material node. Is it an octane problem or rhino 6 problem?
Fabrizio, I have some more info on this. I think this issue is due to your Windows->Settings->System->Display->Advanced Scale Settings->Custom Scaling is not set to 100%. This issue is resolved in the next release of the Rhino6 plugin, but in the meantime, changing this scaling back to 100% should get you operational.
fabrizio_s
Hi Paul,
I'm looking for this path file but I'm not able to find it. Maybe is a path of win 10.
I have win 7 and in this os I have found this window. As you can see font scale is already at 100%.
bye
fabrizio
Sorry Fabrizio, I don't have a Windows 7 PC, so I think you'll need to wait for the next release of the plugin. It is fixed in the current commercial TEST version, but not yet in the Subscription version.
fabrizio_s
Don't worry, I'll wait for the bug fixed version.
Thanx a lot Paul
Bye
Refracty
Hi Paul,
I was refering to this quote and would like to know what does not work now exactly and what the next steps are to make it work.
Is this in McNeel hands?
Thank you
face_off wrote: - Fixes to material Previews - but still not quite right
I have updated the current TEST build for Rhino6 to further fix UI scaling issues (release number has not changed - still 3.08.1.92). Sliders should no longer be disappearing off to the right of the panel, and the RGB color node should no longer have the button misplaced. Can users pls confirm that all UI issues for Rhino6 are now fixed for them, and I will do a full release.
I have updated the TEST builds at the top of this thread with a new standard and SUBSCRIPTION build of the Rhino6 plugin. I think (hope) this version addresses all outstanding Rhino6 plugin issues, so request all Rhino6 users pls download and install this version and let me know if you have any issues.
fabrizio_s
Hi Paul and thanks for the subscription version. So far it seems working well except for the maximum level of values. I tried to enlarge the window but without result. See the images below.
My monitor is 1920x1080 px, Win 7, gtx 1080 ti
bye
fabrizio
Can you pls show me your Windows Font Scaling setting? Is it the maximum level of float numbers, int numbers or both?
fabrizio_s
bye
Return to “Rhinoceros 3D”
