Release Notes for Octane Render SketchUp Plugin 3.08.1.0
This release is mainly to bring in all changes in the Octane 3.08 and 3.08.1 SDK builds. We are approaching the end of the Octane 3 series; there is likely to be at most one more 3.x plugin before we switch to the Octane 4 series.
New features in Octane 3.08
Octane 3.08.1 release notes
Changes in 3.08 and 3.08.1 plugins
We now support SketchUp 2018, in addition to 2017 and 2016.
The new instance based textures in Octane are now supported. These can be used in conjunction with the third party Skatter plugin to create scattered objects with variable textures.
There is a new Settings dialog, available from the Extensions menu in SketchUp (Extensions > Octane > Settings). This currently has only one setting, a drop-down list that allows you to select the default material type used when converting SketchUp materials to Octane. The available choices are Diffuse, Glossy, Metal, Specular, or Toon; Glossy is the default if you have not chosen one. Changing this setting does not affect anything in an existing Octane version of a scene; it only controls the choice of material type when new SketchUp materials are imported into Octane in the future.
Scene conversion and rendering is now completely suppressed when the Octane window is not open, or when the pause option is activated on the toolbar.
Environment settings are now automatically transferred from the Octane view of a scene to SketchUp. When you adjust the sun position in the Octane environment node, SketchUp's sun follows (you need to have shadows enabled in SketchUp to see this, of course). This feature has a couple of limitations:
- SketchUp's lighting model is much simpler than Octane's, so there are many settings on the Octane side that are not copied to SketchUp simply because SketchUp has no way to reproduce them.
- We don't yet support different lighting models on the Octane and SketchUp sides. This means that, if you set the Octane lighting to anything other than Daylight, you will see inconsistent behaviour as the plugin tries to reconcile the Octane and SketchUp versions of the scene. Full support for other lighting models will be added in a future upgrade; for the moment, we only fully support the Daylight model.
The bug that was causing compatibility issues with other 3rd party plugins has been fixed. This should fix the crashes some users have been experiencing when using the Octane plugin in combination with some other plugins.
Please note that the current Octane SDK requires CUDA 9.1 support, which is compatible with Nvidia drivers starting with version 387. Before you install the latest SketchUp plugin, you should check your video drivers and ensure you have the latest version.
Bug fixes:
- The material picker in the Octane window now works.
- You can now use materials from the LiveDB without crashing.
- Node graph changes are no longer lost when the Octane window is closed.
- The Mac plugin no longer breaks when all scene windows are closed.
- Camera settings are no longer carried over when a new scene is opened.
- Changes to daylight settings are now reliably saved.
- In SketchUp scenes with multiple views, the default view is now also saved as a separate render target.
- Re-opening the Octane window no longer resets some of the render settings.
- Several bugs involving proxy objects have been fixed.
- Compatibility issues with other 3rd party plugins have been fixed.
About This Release Series
The 3.06+ release series represents a thorough redesign of the plugin's user interface. The plugin now uses a separate window of its own, similar to the standalone Octane Render application. You can open this window through the Octane button on the SketchUp toolbar, or from SketchUp's Extensions menu.
The Octane plugin window is built from a set of panels similar to the standalone app:
* The Scene Outliner (on the left in the default layout) shows an expandable list of all nodes in the Octane version of the scene. This panel also has tabs giving access to the LiveDB and the local database.
* The Render Viewport (top) shows the image rendered by Octane. This was originally a separate window in earlier versions of the plugin.
* The Node Graph Editor (bottom) depicts a "sandbox" that shows only the material nodes (and linker nodes connecting them to the geometry); the rest of the node graph (geometry, rendering options, etc) is hidden. You can manipulate the material nodes in the same way you would in the Octane standalone app.
* The Node Inspector (right) shows the full details of any selected node, and allows them to be edited by hand.
You can learn more about the new user interface from the manuals and tutorial videos for the Octane SketchUp plugin and the Octane Render standalone application:
* SketchUp plugin manual
* Octane Render standalone manual
* Octane Render 3.06.4 release notes
SketchUp Plugin v3.06 - Introduction Video
Other Recent Changes
* The plugin is now available for Mac as well as Windows. The Mac version has all the same features as the current Windows build, and the two versions will be kept synchronised in future releases. Please note that, like the Windows version, the Mac plugin requires an Nvidia video card compatible with CUDA 9.1. Most recent production Macs have AMD or Intel GPUs; to use this plugin you will need an older Mac with an Nvidia card, a desktop Mac Pro that has been upgraded with an Nvidia card, or a system with an external GPU.
* Added an option to "pause" the connection between SketchUp and Octane. When paused, changes to the SketchUp scene will not be copied to Octane; this allows you to make complex changes to the SketchUp scene without the Octane scene being updated for every step, and then update it all at once when you unpause. There are toolbar buttons for the Pause and Rebuild actions.
* When you add a new camera view in SketchUp, a corresponding render target node will be created in Octane. The camera position and render settings are tracked separately for each render target, and will be saved with the SketchUp model in your .SKP file. When switching cameras, the corresponding render target is selected in the scene outline.
* There are no longer separate menu options for converting a SketchUp material to an Octane one, or for creating a new Octane material from scratch. These are no longer necessary since the new GUI window provides equivalent functionality. Converting a material from SketchUp to Octane is not a separate operation now; it happens automatically as soon as the material is used.
* All information about Octane materials is now saved with the SketchUp scene in the .SKP file. Unlike earlier versions, all texture graphics are included in this; textures are no longer saved in a separate directory. The saved scene also records any changes you make to the material nodes through the node graph editor. This means that you can now transfer a scene file to another computer, or send it to another user, without losing the texture information. However, it also means that scene files containing Octane plugin data are necessarily larger (sometimes much larger) than they were as plain SketchUp scenes, since they now contain all of the image files needed to reconstruct the Octane textures.
Requirements
Software (Windows version):
* SketchUp 2016, 2017, or 2018 for Windows x64; SketchUp 2018 is recommended
* Microsoft Windows 7, 8, 8.1, or 10 for x64
* The plugin is not compatible with any x86 (32-bit) version of SketchUp or Windows
Software (Mac version):
* SketchUp 2017 or 2018 for MacOS; SketchUp 2018 is recommended
* MacOS 10.11 (El Capitan), 10.12 (Sierra), or 10.13 (High Sierra)
* The plugin is not compatible with any version of MacOS earlier than 10.11
Hardware:
* 64-bit Intel or AMD CPU
* One or more recent model Nvidia GPU cards
* Nvidia drivers version 387 or later; CUDA 9.1 support is required
* The plugin is not compatible with AMD or Intel GPUs
Installation
The installer has been completely rewritten. There are now separate installers for the SketchUp 2016, 2017, and 2018 versions of the plugin. You can install more than one of these on the same computer; they are treated as separate applications.
We recommend uninstalling all previous versions of the SketchUp plugin before installing the latest version.
Please note that stable and test releases will not be identified by any special version numbers. Because of potential compatibility issues if different builds of the Octane engine are run on the same system, we believe it is more important to keep plugin version numbers synchronised with the corresponding build of the standalone Octane application and the Octane SDK. If you are having problems, the first thing you should check is that you do not have different versions of other Octane products installed.
Support Information
- Operating system (e.g. Windows 8.1 x64)
- Amount of RAM
- Graphics cards - model (e.g. Nvidia GTX 690 with 4GB)
- Nvidia driver version (e.g. 390.77)
- SketchUp version (e.g. SketchUp Pro 2017 version 17.2.2555 64-bit)
- Skatter version (if you have it installed; e.g. Skatter 1.2.0)
- OctaneRender for SketchUp version (e.g. 3.08.1.0)
Download Links
* Windows plugin for SketchUp 2016
* Windows plugin for SketchUp 2017
* Windows plugin for SketchUp 2018
* Mac plugin for SketchUp 2017
* Mac plugin for SketchUp 2018
* Windows demo plugin for SketchUp 2016
* Windows demo plugin for SketchUp 2017
* Windows demo plugin for SketchUp 2018
* Mac demo plugin for SketchUp 2017
* Mac demo plugin for SketchUp 2018
Earlier Changes
These changes were made in earlier 3.x releases of the plugin, and are still relevant in the latest release:
* Like the Octane 3 standalone version, the SketchUp plugin uses the new single sign-on system. You still need to have purchased a license for the SketchUp plugin, but it will now be checked automatically when you log in using your Otoy account credentials; you no longer need to keep track of user IDs and passwords for individual licenses. The new authorization management window is a modal dialog where the user can sign out and sign in. It also informs the you under which name you are signed in and if that sign-in was in offline or online mode. When a user signs out, all of your licenses which were activated on this computer will be deactivated. This requires that all these licenses are currently not in use by other Octane processes; if that is not the case the sign out will fail.
* Because most rendered images are now stored in your computer's main RAM instead of your video card's RAM, all Octane 3 applications, including the SketchUp plugin, will frequently use a good deal more memory than their Octane 2 equivalents, especially for high resolution renders. You should keep this in mind when upgrading.
* 3.03+ releases include experimental Pascal GPU support. Please note that we are still working on performance issues there.
* Support has been added for the Skatter plugin's Render Only mode.
Known Issues
We hope to fix these in a coming update:
* The Mac installer is not signed yet; we're still organising the details. For the moment, if Finder gives you an error when you run the installer, you can override this and run it by right-clicking on the installer and selecting Open from the popup menu.
* The toolbar buttons on the Mac plugin sometimes show incorrect pressed/unpressed states. This is a SketchUp bug that we will try to work around.
* The status bar text is not reliably updated in the Mac version. This is also due to a a SketchUp bug.
* Custom resolution in the material preview does not work.
* Once a texture has been copied from SketchUp to the Octane version of the scene, any changes made to either version of the material are not reflected in the other version. (This is a simplification applied to ensure the two versions of the material are handled correctly in this version of the plugin; we intend to add automatic transfer of changes from one to the other in future, where the different properties and behaviour of Octane and SketchUp materials allows it.)
* Re-applying the same texture after an undo may fail to work. This is a bug in SketchUp, not related to the Octane plugin.
Release History
3.08.1 - Synchronize with final Octane 3 SDK.
3.08.0.11 - Fix compatibility issues with other plugins; reinstate the Mac build.
3.08.0.9 - Support SketchUp 2018; fix proxy and Skatter issues; support instance-based textures; add settings dialog.
3.07.0.14 - Fully suppress scene conversion when no Octane window is open; automatic transfer of environment settings from Octane to SketchUp; fix material picker and LiveDB bugs.
3.06.4.10 - Better isolation when Octane is paused; bug fixes to Mac toolbar and installer.
3.06.4.5 - New Mac build.
3.06.4.0 - Highlight render target when changing camera; add pause and rebuild buttons.
3.06.2.5 - Track separate render targets for each SketchUp camera; add menu command to rebuild the Octane scene.
3.06.1.4 - Fix slow geometry transfer when render window is not open; add scene outliner to default view; save workspace layout with scene file.
3.06.1.2 - Initial public test release with the new user interface.
Octane Render for SketchUp 3.08.1.0 Stable Release
Thank you guys.
PS. Captain - it would be more clear to have a short list of what has been fixed since a previous release
- _qmvc3WkfIhgYS
Can someone confirm if this is in fact stable? Can I use this version in production?
smicha, it's listed in the release history. So basically nothing has been fixed
smicha wrote:Thank you guys.
Win7 Sp2____2xGTX1060 [email protected]____Su17.2.2555 and Su18.0.16975____SketchUp Plugin 4.00.0.17____4.00.RC7 Standalone
johlanga wrote:smicha, it's listed in the release history. So basically nothing has been fixed![]()
That's why I am asking for a very short notes about each release, instead of pasting all previous notes...
A very short notes indeedsmicha wrote:johlanga wrote:smicha, it's listed in the release history. So basically nothing has been fixed![]()
We can have faith.....
PS: Nice that you still post in the SU forum
- CaptainCrowbar
Normally I'll put a list of changes specific to a particular release, but in this case the new Octane SDK is really the only substantive change recently. At the moment most of our work is dedicated to the upcoming Octane 4 release. The SDK team tell me there will probably be a final 3.08.2 release in a week or two; I'll make another plugin build for that, and that will probably be the end of the Octane 3 line. I expect to make a 4.0 alpha plugin available soon, probably next week.
- _qmvc3WkfIhgYS
Octane 4 will not be available with the octane 3 license correct? We have to buy Octane 4?CaptainCrowbar wrote:Normally I'll put a list of changes specific to a particular release, but in this case the new Octane SDK is really the only substantive change recently. At the moment most of our work is dedicated to the upcoming Octane 4 release. The SDK team tell me there will probably be a final 3.08.2 release in a week or two; I'll make another plugin build for that, and that will probably be the end of the Octane 3 line. I expect to make a 4.0 alpha plugin available soon, probably next week.
That means that you will not provide a working Sketchup plugin for Octane 3 customers?
- Seekerfinder
Nope. Keeps crashing. Annoys the heck out of us when trying to get something out the door.patrickbarnekow wrote:Can someone confirm if this is in fact stable? Can I use this version in production?
In fact I think they should not charge money for it untill it’s at least stable, notwithstanding features.
