Hi All,
I'm hoping someone can help,
I've been working with a master computer (Windows 10 up to date, C4D R17 up to date, Octane 3.08 up to date, 2x 1080Ti FTW3 drivers up to date) and a slave (Windows 10 up to date, Octane Slave Daemon 3.08 up to date, 4x 980Ti FTW2 drivers up to date) for over a year now without a single problem.
Today the slave started giving me the following error:
CUDA error 2 on device 3: out of memory
CUDA error 2 on device 0: out of memory
CUDA error 2 on device 2: out of memory
-> failed to launch kernel(kernel31)
device 3: path tracing kernel failed
-> failed to launch kernel(kernel48_tex)
device 2: path tracing kernel failed
Failed to allocate page-locked memory
-> kernel execution failed(kernel25)
CUDA error 2 on device 1: out of memory
-> failed to deallocate device memory
-> could not get memory info
device 1: failed to upload data texture 28 of context 0
-> failed to launch kernel(kernel26)
device 0: path tracing kernel failed
Now before someone states the obvious that I'm out of memory, I don't think that is the main problem as I've been using this setup for over a year on very similar projects with no problems at all. (Exterior scene with a single building, single light source bit of grass and a few trees)
What seems suspicious to me is the "could not get memory info" message. How is this even possible?
Please help as I'm on a deadline and without the slave being fully operational I won't be able to deliver the project that I have already spent a week on...
Your help would be much appreciated,
Many thanks in advance,
Laszlo
Network Render Stopped Working
Possibilities
1- problems with driver
2- corruption on gpus
3- out of memory
Solutions
1-Fix drivers or OS
2-Check with single gpu for testing
3-Check with simplier scenes
3- out of memory
Solutions
1-Fix drivers or OS
- laszlosomogyi
Hi Aoktar,
Thank you for your quick reply,
Will do the checks and get back to you about my findings,
Many thanks,
Many thanks,
