3ds max export on latest version
BenterA
Hi guys,
usally i tend to stay in 3ds Max, when renderding in Octane, but now i have to rendern an animation in the Standalone Version as SA seems to handle the amount of geometry much better/ more stable.
I know it worked in older versions, so did anything change when it comes to exproting animated cameras (Octane Camera in Max)? All objects exports work fine but i can`t find a way to get my camera animation into the SA?
Thanks in advance
Ben
paride4331
Hi BenterA,
Octane for 3dsmax 5.08 has an animated .abc camera issue already reported to developers.
Workaround is exporting animated camera to .abc then importing separately into SA.
3dsMax > export selected > .abc
BenterA
Thanks for your answer!
I tried to import the Camera seperately as an alembic. But unfortunately the Cam Node does not have any inputs to connect it? Do you know what the reason behind that could be?
Many Thanks
Ben
paride4331
Hi BenterA,
right mouse button select > ungroup
BenterA
Thanks paride,
you mean the camera node (i imorted it as Geometry-Scene). Unfortunately there is no "ungroup" option in the right click menu.
paride4331
Hi BenterA,
I must have misunderstood, attached a screenshot.
BenterA
Thank you for you help! I have tried it this way, too. But as you can see, there is just no way to connect it.
paride4331
Hi BenterA,
Did you try 5.09, .abc camera was fixed.
BenterA
Thanks a lot, works fine now!! :)
Return to “Plugin Discussion/Support”
