Version 4 - XB2 (Test release1)
coilbook
aoktar wrote:
coilbook wrote:has anyone tried to render animation and see if processing geometry is still slow each frame like in octane 3? Thanks
Much faster!
coilbook
rleuchovius wrote:Thanks Aoktar, looks awesome!
My scene translation went from 103 seconds to 43 seconds. That will be a lot of saved time in testing and rendering!
Nice. Hopefully in the future it will be almost realtime like they promised
raulofs
Hi, aoktar
the plugin XB2 doesn't have denoiser support in individual passes example, light pass or diffuse and reflection?
Outstanding work!
Partially wrong misleading. Just try without any materials for seeing the geometry performance difference. And It will consist from two phases. Mesh creation from plugin and Octane processing for meshes. First phase still same, second was accelerated.
Goldorak
Ahmet is correct - Brigade speed in V4 is maximally limited by to the host application's ability to feed the engine new data, and also includes any time taken to generate or load meshes in the host app before sending it to the engine (the engine's ability to load this data is 10x faster). Once loaded, moving objects should be order's of magnitude faster than V3 with big mesh scenes for example. We're working on some game engine like demos (e.g. Unity or UE4) to show off V4 speed along the lines of our old Brigade demos.
BCres
May be too soon for this...but is there a time frame for full release of V4 and any idea of the upgrade costs to version 3 owners?
Thanks.
Tag12345
Still waiting for more stability with v4.
Seems like people are correct with it being faster and more robust with things like cleanup,etc
Though, it seems geometry and crashing with large scenes is still a struggle.
Octane can handle 12M polys fine, but cant do 30m (2 characters in a scene)
idk if its a c4d thing, but I know in standard and in viewport its hella smooth, octane just freezes up whether using OoC or non-OoC settings
I run 3 GTX 1080Tis , using a 1050ti to run my 3 monitors. The scene probably takes up 6-7g in vram last I checked, though OOC should work for it.
Never had luck with this with 3.08 either so Im wondering if thats something being worked on with v4 for geometry and Larger scenes
mykola1985
any ETA on 3ds max plugin release date?
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
dinf
mykola1985 wrote:any ETA on 3ds max plugin release date?
In C4D section?
| Win 10 | 64 GB RAM | AMD 5900X | RTX 3080 12 GB| C4D 21| C4Doctane v2022.1.1|
lassinger
aoktar wrote:
MrDavids wrote:Why does my HDRI disappear and turn black when i view the AI Denoised result? Please see attached.
Not sure! This kinda behaviors are on core level. Possibly due being a render pass.
...i have the same problem...
hdri is not visible in liveviewer under ai denoised-result.
and..:
if i render the image out, the denoised image has a different colour-/lightfeeling than the image without denoising. and in the rendered denoise-image the hdri is missed too...
and an example from an animation..:
the denoised version (right) has some shiny springy plotches...
http://www.larsnaglerworks.com
http://www.behance.net/LarsNagler
http://cargocollective.com/larsnaglerworks
Mac Pro 5.1 :: 3,33 GHz 6-Core Intel Xeon :: Mac Pro Nvidia GTX680 4 Gig :: 32GB :: C4D 13 Studio :: Octane Renderer
OP-1
Return to “Releases”
